09-22-2008, 04:32 AM | #1 |
RCC Addict Join Date: May 2008 Location: On the rocks
| MM Questions
Never owned a Mamba max before. I was thinking of going duel MMs w/ some 45T lathes, 2 cc becs and a couple 8711s. Can you run 4C Lipo on these escs? I notice the specs say up to 3C but im seeing 4C dual setups. Thank You |
09-22-2008, 05:14 AM | #2 |
Newbie Join Date: Dec 2006 Location: Estonia
As long as You disable the internal bec, mamba max will take 4S.
09-22-2008, 07:40 AM | #3 |
09-22-2008, 11:22 AM | #4 |
| No. Check out this thread about external BEC wiring: Definitive wiring diagrams for BECs Rx Servos Motors etc. On my rigs I just remove the red wire going from esc to receiver completely (so the internal bec isn't used at all) and plug everything to the receiver as normal. |
09-23-2008, 07:27 AM | #5 | |
09-23-2008, 09:19 AM | #6 |
RCC Addict Join Date: Nov 2007 Location: BV
The mamba's internal bec will still operate if unplugged, but with no load on it, it won't cause overheating problems. I'd also advise a fan on the ESC if you intend to run 4 cell. Look over at RC monster, there's a lot of good info about 4 cells on mamba's there.
