03-09-2009, 09:42 AM | #221 |
Moderator Join Date: Jul 2007 Location: Texas baby!
wrightcs77 - if you use a digital trim button to control the mixes, it will stop when you reach 0% if you arrived there from holding a the trim button, you have to release and repress the button for it to go negative. engineerjoe - negative mix is possible on the fly, just use whatever button you have programmed to change the mix and lower the percentage from +100% to -100%. That will make the axles rotate opposite of each other. If you have the setup I listed on the first few pages of this thread, the rear axle is independent of the front axle and therefore rear dig is possible without influencing the front. List your setup, how the ESC's are plugged into your RX and any programming. To answer your question directly, you can use any dial to control the rear axle, set the function of the dial to control the channel that you have the rear ESC plugged into. Using my method, you hit a button and you can control the rear ESC all by itself. |
03-09-2009, 09:47 AM | #222 | |
#1: You would have to use the second condition function to setup another mix and reverse the values. It would be a two step process, switch to second condition then activate the mix, and then you would have to repeat it to shut it off. I don't see a situation where I would really use this though. It would get you a reverse penalty and I can already turn my rig around simply using dig. If I was going to get a reverse penalty I would just take a reverse and get a better line at it. #2: Yes you could program the dial to control your rear dig but you would have to get it turned back to zero for the wheels to stop spinning. I did this for a short time, not a great setup. When you would you be wanting to do a rear dig that you wouldn't want your wheels turned? If you had to control the rear dig speed with a dial that would cause you to take your hand off the wheel you would be sacrificing control. The wheel method for rear dig actually works really well, I may go to it on my 4PK so I have an open channel for winch down suspension. | |
03-09-2009, 10:03 AM | #223 | ||
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
I don't see myself using either of these functions very often either, but I just want to have them in the bag of possibilities. yes, the reverse mixing would cause a reverse penalty, but might save 2-3 reverses. I'll probably try both rear dig setups and see which one I like better. | ||
03-09-2009, 10:06 AM | #224 |
03-09-2009, 02:42 PM | #225 | |
Pebble Pounder Join Date: Sep 2008 Location: Scotland Neck
03-09-2009, 02:44 PM | #226 | |
03-09-2009, 02:47 PM | #227 |
| Just need to get everything to the point that I like it before I add that. I don't want to have everything 80% done. I have plenty of room on the rear axle for the servo though. It "SHOULD" be fairly strait forward.
03-14-2009, 05:27 PM | #228 |
Rock Stacker Join Date: Mar 2008 Location: Chandler
This post has been by far the most helpful post I have read on the site. I had my berg up an running within minutes of opening the box the radio came in. Drove it today, worked awesome. Thanks for all the great information. |
03-21-2009, 08:48 PM | #229 | |
Took some shots today while out on the rocks. Have to thank Jason again for the painting the body for me. Now that is sponsor support | |
03-30-2009, 06:40 PM | #230 |
Quarry Creeper Join Date: Dec 2008 Location: Aurora Colorado
Harley, I have been using my 4pk a month now. I am not disappointed at all that I spent all that money on it. I now need to buy 6 more receivers. LOL I am getting my buddy who has zero RC experience into crawling and he is purchasing one also. Now if Losi would just hurry up launch their new crawler. |
03-30-2009, 09:03 PM | #231 | |
Glad to hear your buddy is jumping right in, hopefully he likes it as much as us! If you ever need anything let me know. | |
04-01-2009, 08:03 AM | #232 |
Quarry Creeper Join Date: Jan 2008 Location: Calgary Canada
| Hey Harley ,,I'm a little lost here with the super setup . I made the change from the DX6i to the 4PK and I love it ,glad to be rid of the sticks . I have my 2.2 setup with your VF setup as well as the one touch button option , Awesome ,,works great. Your instructions are very helpful ,I consider myself to be Tx stupid but I managed to get this far with your setup tips . The super setup makes my head hurt trying to figure it out ,,lol Ok ,this is the Vid I want for setting up my super I believe . My question is ,where do I plug everything in on my reciever ? 2 servos , 2ecs's ,1 ccbec Does each esc have to be setup independently ? And then I do your settings that you show in the vid ? grabbing a new Rx for my super today ,hope to get it setup . |
04-01-2009, 08:17 AM | #233 | |
That is the video you want. I think you have it for the most part, the only exception being the CC BEC. Since there are only 4 inputs you will have to wire the BEC direct to the servos. If you need I can give you a wiring diagram to do this. For my setup I demonstrated, this is the configuration for the plugs. Ch 1: Front Servo Ch 2: Front ESC Ch 3: Rear ESC Ch 4: Rear Servo I will have to look back quick and see if I listed all the specs, I don't recall typing out all of the settings. If I didn't already than I will try to do that ASAP (probably after ECC though). If you need anything that I missed though feel free to post/pm, I am sure others are thinking the same. Since I don't own a super anymore (hopefully again soon though) I haven't verified everything other than on the display. The display is such a great tool for checking setups though. | |
04-01-2009, 08:30 AM | #234 | |
I will keep watching for the super write up . Thanks for your help . | |
04-01-2009, 09:18 AM | #235 | |
You can do most of the wiring by buying Y-Harness from the hobby shop and pulling certain pins out. Or you can do it the best way and redo the plugs on your servos and such. That is up to you but the wiring diagram will show you what you need to accomplish. A tip, make sure that you can plug the signal wire back into the plug on the CC BEC so that you can program it with the Castle Link | |
04-01-2009, 09:29 AM | #236 | |
04-01-2009, 09:33 AM | #237 |
| As long as you are using 2 ESC's that are the same (outputing the same voltage) you are fine. You can disconnect one if you like obviously |
04-01-2009, 04:55 PM | #238 | |
I'm running twin 3 cell lipo ,one batt for each esc ,I assume this must change the diagram some what ? | |
04-01-2009, 04:57 PM | #239 |
Oh ,I think I see ,,obviously just run one batt to each esc ,one ccbec or two ?
04-01-2009, 08:19 PM | #240 | |
I know Austin (Gatekeeper) has to run 2 BEC's on his since he is running two 300+ oz servos. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
