Thread: 4PK Setups, Tips, Tricks and Help
Old 05-04-2009, 12:38 PM   #281
Originally Posted by JohnRobHolmes View Post
The tekin controllers have stronger drag brake right now.
Well John if yours were out right now you would be in luck..Well I guess I would be....I am needing something figured out asap!I would love to have two of your speed controls and two 35 turns and a 11 volt Lipo...Too bad you never have ANYTHING in stock........Well I guess you have some lipos.....Not much good without the motors and speed controls...
Jeepial is offline   Reply With Quote
Old 05-04-2009, 09:33 PM   #282
THE Y-TOWN OG
dboy1k's Avatar
does anyone know if there is a way to set up the rear scroll so it will go back to 100% with out rolling it up to 120%? i scroll down to about40-70 no problem without looking at the screen but when i go back up to full 4x4 i go past it or sometimes not enough.
i hope i make sence here
dboy1k is offline   Reply With Quote
Old 05-30-2009, 12:58 AM   #283
Thanks for the tips Harley. I set up my 4PK on my Losi tonight using your tutorial.
wrightcs77 is offline   Reply With Quote
Old 05-31-2009, 10:10 PM   #284
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Your welcome
Harley is offline   Reply With Quote
Old 05-31-2009, 10:11 PM   #285
20K Club
Harley's Avatar
LOSI CRAWLER SETUP
This is simple and strait forward, just want to give you guys a quick reference.
Go to a clean model and name it for reference first.
This is what your home screen will look like.
Next you need to decide what switch you want to use for your dig. I am programming this using DT2 because I am guessing many of you will use this one.
Go to the DIAL menu:
Set DT2 (or whatever dial you choose) to read: CH3 100 / NOR
I chose to also clear the rest of the settings on the screen so I can't screw anything up while driving, this is just personal preference.
This will give you a standard 3 position switch on the 3rd channel. Pretty simple
Now to adjust your end point adjustments (EPA) so that your steering servo is only moving the proper amount do the following:
Go to your EPA menu:
With the rig in the air (tires not touching the ground) adjust the ST values until you get the amount of steering you want. I suggest going to full lock and then dialing it back a fair amount since this truck seems to extremely weak CVD's:
These values are just for example, actual values will depend on servo and servo horn length you are using.
Now repeat this if you want to setup a dig servo:
With the rig in the air (tires not touching the ground) add a small amount of throttle and adjust the 3rd channel EPA's until the dig engages and disengages with full engagement:
Any questions just let me know, and don't blame me on your steering end points breaking your CVD's
Old 06-18-2009, 09:40 AM   #286
Im Brandon
Brandon's Avatar
Anybody with a 4PK needs to check this out!!
http://www.redrc.net/2009/06/team-ep...ah-li-fe-pack/
Brandon is offline   Reply With Quote
Old 06-20-2009, 04:35 PM   #287
hey guys... NEED Help.. how can you have front dig, 4wd, rear dig using any switch as a three position switch... Simple put... i want it to act like a micro dig switch...
thehammer is offline   Reply With Quote
Old 06-20-2009, 04:54 PM   #288
20K Club
Harley's Avatar
I'll see what i can do but don't think I'm an going to have any luck.
Old 06-20-2009, 04:59 PM   #289
Moderator
whoodie's Avatar
X2, I'm pretty sure that is not possible, unless you use a servo to actuate dig switches. But that kind of defeats the purpose of a 4PK.
whoodie is offline   Reply With Quote
Old 06-20-2009, 05:32 PM   #290
thank you for looking in to it... waiting patiently... FYI .. running two tekin fxr's...
Old 06-21-2009, 12:38 PM   #291
Go back to page 4 and look at the video/setup.
It is on two switches rather than one 3 pos switch but works the same.
Ya do need the four channels of and two pre-mixes of the 4pk to get both digs on the trigger but very doable.
oldhippie is offline   Reply With Quote
Old 06-21-2009, 12:44 PM   #292
20K Club
Harley's Avatar
There just isn't any way to do what you are looking for. MY suggestion is to learn the setups that we have posted and then see what you may want to modify. These setups are better overall and don't allow you to mistakenly throw your truck into something you didn't expect.
Old 06-21-2009, 01:32 PM   #293
20K Club
Harley's Avatar
Hey guys, I have updated the first post of this thread to make setups easier to find. This thread is getting pretty long and I don't really expect every single person to read the whole thing. So if you know anyone needing help you should be able to refer them right here and expect them to be able to find what they need easily
Old 06-22-2009, 03:25 PM   #294
thanks for your reply....
Old 06-23-2009, 04:59 AM   #295
Default 4pk and twin FXR's
Harley, havin a bit of an issue w/ my super.ive been drivin it more lately, and getting better, but been noticing that the rear motor isnt powering up exactly when the front motor does. It seems to be underdriving compared to the front.
Ive reset my radio calibration, my profiles are exactly the same, and all my settings are 100%. Kinda twisted on this one:?. If i add offset into the mixing, would that solve the problem? It seems that it would, any help would be appreciated. Thanks
scatterbrains is offline   Reply With Quote
Old 06-23-2009, 05:43 AM   #296
I had the same issue, I went back into mix 1 and uped the offset to 6% and its on the money now!!
hbj069 is offline   Reply With Quote
Old 06-23-2009, 08:18 AM   #297
20K Club
Harley's Avatar
Just as long is this doesn't screw up how your truck acts in reverse you should be fine doing that. Sounds like you are just fighting good old fashion Clod stall. Dual ESC's can never completely cure the problem. You could try the old techniques like dropping a tooth on the rear pinion too.
Old 06-24-2009, 09:48 AM   #298
Thanks harley, yeah anymore than like 5% offset jacks with my rev. Guess ill drop a tooth in the rear and go from there. Thread has been a big help
Old 06-24-2009, 10:37 AM   #299
20K Club
Harley's Avatar
Make sure your motors are in good shape too, you may just be trying to mask a problem somewhere else. It has been longer than I care to admit since I have owned a super though.
If I can help with anything else on the radio let me know.
Old 06-24-2009, 10:55 AM   #300
No prob, motors are GTG goin to do the Pinions to 8/7 and see what it does.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html
Posted By For Type Date
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? This thread Refback 10-05-2011 06:51 AM
• Afficher le sujet - Mon nouveau joujou This thread Refback 10-05-2011 06:04 AM
