10-05-2009, 06:08 PM | #481 |
| Yes, 1/8th scale. Just asked an XRAY driver, when it happened to him it was over 100 outside, and the RX was inside a sealed box, inside the body with no air flow over it. I imagine it was cooking |
10-05-2009, 06:16 PM | #482 |
Moderator Join Date: Jul 2007 Location: Texas baby!
| I am curious if it was the Rx generating too much heat (maybe 18 Watts (6V, 3A)) or an external heat source (Engine, etc...) or a combination of the two. Perhaps a cleverly placed heat shroud (read: aluminum tape) would have cured the problem.
10-05-2009, 08:46 PM | #483 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
OK I just reread this whole thing again and the question has been asked twice and never answered so I'm guessing it can't be done BUT_ Is there a way to set the mix % wheels so they only go 0 to 100 rather than -120 to +120. It really is a pain to stop and look every time ya spin the wheel. I really want to start using the wheels a lot but am afraid of the reverse penalty and the time lost stopping and resetting them back to 100. I was gonna try and put a stop on the dial but it is not constant. It really defeats the usefulness of the mixing % feature for me not to be able to change on the fly with consistency. I know I'm ham fist/brained but this could be easier. I'm really thinking of trying to drive sticks again, which I really sucked at. I really am about the only person running a 4pk (leave alone futaba) around here. Help |
10-05-2009, 08:52 PM | #484 | |
In what situation are you having a problem where you could be going to -120 and getting reverse? There is no way to way to put a limit on that percentage as far as I am aware. I use the DT buttons for mixing because it is very easy to keep track of. I never find a situation when it is worth going lower that 70% rear mix though. I find +120 very useful though. | |
10-05-2009, 09:31 PM | #485 | |
10-06-2009, 05:29 AM | #486 | |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
I would have to look and find the test, but I am pretty sure it has a video. IN a shoe box, hair dryer and a temp gun. I believe they thermal at 142*, then go into fail safe until temps go down below 142*. They have tried heat tape, drilled radio boxes......you name it. It does not matter if it a Losi (where the rx is in the front of an 8th buggy) or a traditional radio box. It is not all rx's either, kind of a hit and miss thing. It does happen enough that a lot of drivers will not run Futaba and have gone to Spektrum, even though Spektrum is not as comfortable or adjustable. The Starting Grid has a great thread on it, but not many people from here are probably on that site. I don't even know how you get access to the site, as I have been a member for a long time and it is a non-public site. | |
10-06-2009, 06:48 AM | #487 | |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
might sound goofy but i run my futaba stuff on my losi 8 2.0 and on my 8T 2.0. I went to the losi lipo and a bec ( in the radio box) and it eliminated all those problems. I had jr 8711 all the way around and found them to be power hungry and creating thermals just as you described. i have 8 R603's and 604's and yes the thermal when put under big servo loads. You may also want to look at the 4pk settings in regards to digital vs analog and servo speed. the futabas are sensitive to the return rate of the faster servo and require some serious tuning. Quote:
10-07-2009, 07:44 PM | #488 |
Quarry Creeper Join Date: Dec 2005 Location: kerrville
can the PS1 be set so instead of clicking a Mix on/off with each click , that it is off when held down but turns back on when you let off the button?
10-07-2009, 10:19 PM | #489 |
TEAM RCC Join Date: Jul 2006 Location: Novato
Thanks Harley i love my 4pk |
10-07-2009, 10:37 PM | #490 | |
No problem man! | |
10-12-2009, 03:35 PM | #491 |
Pebble Pounder Join Date: Sep 2009 Location: On tour in Iraq!
Well, got my 4pk today and I must say it was a little bittersweet. I cracked the box tonight at work and started pouring over the manual and this thread getting the RX all setup for not only DIG but also four wheel steer! It was for this very reason I returned the 3PM I had bought not a week earlier. Everything went extreemly smoothly, the menus were a little confusing at first but with the help of this thread I got myself where I needed to go. *SWEET* About 2 hours later I get home and get ready to install the R604FS into my pet project. Following the setup instructions from here: Front steer in CH1, ESC in CH2, DIG in CH3 and Rear steer in CH4. But wait... there seems to be something funny here... the remaining slot, which was intended for my BEC, is not tagged Batt as expected. Infact its tagged DSC which, according for the manual, is intended for operating the receiver directly, bypassing the radio. The Batt acutally shares a socket with CH4. This may mean that I can't run my BEC without some crazy wiresplicing. *BITTER* This is really kinda dissapointing that Futaba would make their only 4 channel receiver that is compatible with the 4PK have this sort of issue. I know its not built for a crawler but I don't think its so crazy to imagine someone using all 4 channels *and* a BEC/Batt. So the question becomes... can I put my BEC in the DSC socket anyways as long as I remove the orange (signal) wire or should I just hire an Electrical Engineer? Last edited by oSPANNERo; 10-12-2009 at 04:02 PM. Reason: content |
10-12-2009, 04:04 PM | #492 |
10-12-2009, 04:30 PM | #493 |
10-12-2009, 05:26 PM | #494 |
| Ok, I have my BEC (with the orange wire removed) in channel 2 since that is vacant. I suspect, that if you plugged in the BEC (with orange wire removed) into the DSC, that it would work just fine. Remember that all of the positives and negatives for all of the channels are common to each other, it is only the signal that is different.
10-12-2009, 05:39 PM | #495 |
I have to honestly say that I have never tried plugging my BEC into that port so I can't answer from experience. I would be interested to know your final result though so I know in the future |
10-12-2009, 05:42 PM | #496 |
Wish I had a multimeter to check the pins... I am just worried that the DSC socket is actually isolated since it is meant to connect back to the reciever. Especially since when you read pg 123 where it tells you to turn on the power for both the TX and the RX when using the DSC connection. In that case the DSC socket would have to be isolated either on the RX or on the TX or both to prevent one power source from feeding back into the other, no?
10-12-2009, 05:44 PM | #497 | |
10-13-2009, 07:32 AM | #498 | |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
I finally got around to trying this and it works great!! Here's how to get a push button front dig on a Losi crawler or a MOA with dig switch: 1. Set PMIX1 or PMIX2 to the following settings: UP: +22 (You can adjust this like an EPA to avoid hurting your servo) DOWN: 0 (you may have to swap this with DOWN depending on how your dig servo is set up) OFST: -100 MST: CH3 SLV: CH3 MXMD:MIX TRIM: OFF Then go in and set your preffered switch to PMIX1 (or PMIX2) and I have it set for NOR so it only engaged dig while the button is pressed. | |
10-17-2009, 05:44 PM | #499 |
Rock Crawler Join Date: Jun 2008 Location: dublin
nice thread harley very helpful |
10-21-2009, 11:05 PM | #500 |
varcor.org Join Date: Aug 2005 Location: 757
hey harley, any ideas why my HS-645MG is humming loudly in neutral? even when i go full lock, i can still hear it hum. i swapped back to my dx3r setup and it doesn't do this. on the 4pk, i have the rxsetup (?) set to normal with the C2 setup (604FS rx). on my mrc, ch 1 is the HS-645MG, ch 2 is a sidewinder micro, with the CC BEC in ch 3. the CC BEC is set to 6v from a 2-cell lipo. did i miss a setting for the analog servers or something else?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
