09-03-2010, 07:30 AM | #1001 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
What do you mean external antenna? I took mine off when new, One less wire to get screwed up. never no problems and I have had mine for almost 2 years now. Snip it and forget it. you will be fine |
09-03-2010, 07:56 AM | #1002 | |
Definitely not needed, however I still run one most of the time. | |
09-03-2010, 07:57 AM | #1003 |
| I'll probably have one shortly after Nationals. The existing setup still works great, the only thing you need to change is the display type from Sevo View to Dial/Trim. |
09-03-2010, 11:07 AM | #1004 | |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Is there a way to program it so both directions are scaled. Based on the crawling we do here, I would like to give it a try. I can imagine a couple of circumstances where slowing down the front motor would be beneficial. I have been known to climb obsticles in reverse. | |
09-03-2010, 11:37 AM | #1005 | |
09-03-2010, 04:38 PM | #1006 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
And it doesn't say anything abut the PMIX's being on or off even when I hit the buttons for them. So now that I think about it, if I hit an errant button on course, I have no way of knowing if I am in 2wd,4x4 or FWD unless I pull the throttle. In the wrong position, that could be an issue.
09-03-2010, 04:41 PM | #1007 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
I have mine setup to vibrate when one of the mixes are activated or deactivated...don't even have to look at the screen. Just got my case in today...wtf can I stuff in all the empty slots?? |
09-03-2010, 04:51 PM | #1008 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
09-03-2010, 05:09 PM | #1009 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
if i use the ultimate moa setup with dual esc's will i need a dig system or does that work like a dig system?
09-03-2010, 05:17 PM | #1010 |
09-03-2010, 05:33 PM | #1011 |
sweet i need one of these |
09-03-2010, 05:41 PM | #1012 |
Rock Crawler Join Date: Mar 2004 Location: Albany
I wish I could just unplug it lol but my receivers bounce from my crawlers to scalers to 3s 18t to my SC8E so the range varies widely. Thanks guys will give Futaba a call.
09-04-2010, 12:55 AM | #1013 |
Quarry Creeper Join Date: May 2010 Location: Longmont, CO
09-04-2010, 03:39 AM | #1014 |
Pebble Pounder Join Date: Jul 2010 Location: Seattle
If you guys are looking for a slightly larger alternative to the Futaba hard case, I just picked up a Vaguard VGP-13S photography hard case. They're very rugged and only cost about $50 (check Amazon, buy.com). It includes full foam with cube cut-outs so you can customize it any way you like. I'm going to make slots to carry some lipos and a few other things. I'll post some pics as soon as I get it set up.
09-04-2010, 12:29 PM | #1015 |
09-04-2010, 04:58 PM | #1016 |
Rock Crawler Join Date: Aug 2005 Location: Illinois
It is important that you shut the radio off and then turn it back on. Otherwise it will not change. J |
09-04-2010, 05:39 PM | #1017 |
09-04-2010, 06:03 PM | #1018 |
OK. I will check into it.
09-05-2010, 05:09 PM | #1019 |
Hey I followed the video for setting up 2 esc's for my XR-10 and now if I hit front dig my rear motor spins in reverse and same happens if I hit my rear dig with the front motor. Now if I run my 3rd channel sub trim at +25 it stops all this but my rear motor in 4wd is twice as fast as my front and also creates a ton of stall in my front motor. I played with a bunch of settings but could only get one issue to leave but creating a new one any ideas what to try?
09-05-2010, 05:37 PM | #1020 | |
Then the easiest thing to do is start with a new model memory and retry. Sounds like you had some pre-existing settings in there or missed something in the setup. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
