09-07-2010, 09:50 PM | #1041 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
You should be able to plug the BEC into the DSC port shouldn't you? It should be a power in but not a power out port on the reciever.
09-07-2010, 10:29 PM | #1042 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
09-08-2010, 12:09 AM | #1043 |
09-08-2010, 12:09 AM | #1044 |
09-09-2010, 10:35 PM | #1045 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Hey guys. Gonna setup 4pks and dual FXR's tonight, for the first time. I will follow the setup instructions here from Harley, but have one question. (BTW, I am a new Futaba owner coming from Spektrum so learning) (Also new to MOA's) When I calibrate the radio throttle settings to the ESC's, do I have the radio pre-programmed with Harleys setup, or a clean model memory with esc's plugged into ch 2 and ch3? I have 4PKS and it has R614FF receiver |
09-09-2010, 10:55 PM | #1046 | |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
Either way, it's really easy to recalibrate the FXRs to the radio. I actually only remembered to calibrate them because one was coming on sooner than the other and giving me interesting handling.... | |
09-12-2010, 10:16 PM | #1047 | |
Worked perfectly! Thanks Harley, and guys for all of this 4pk programming help/tips Very impressed with the Futaba 4PKS. Makes my DX3R feel "Toyish" | |
09-12-2010, 11:06 PM | #1048 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
So I just watched your newer vid on the 4pk set-up...I have been running your OG set-up and just changed to your new set-up and now I have a question?? my set up is as follows..but my issue is the "MODE" mine does not want to go to the "ON" I put the "MODE" to ACT and it shows like this... PMIX1 FWRD: -100 BRAK: -100 MST: TH SLV: TH MODE: ACT (OFF) OFST: 0 MXMD: MIX TRIM: OFF PMIX2 FWRD: -100 BRAK: -100 MST: Th SLV: CH3 MODE: ACT (OFF) OFST: 0 MXMD: MIX TRIM: OFF in you youtube vid it shows like this... PMIX1 FWRD: -100 BRAK: -100 MST: TH SLV: TH MODE: ACT (ON) OFST: 0 MXMD: MIX TRIM: OFF PMIX2 FWRD: -100 BRAK: -100 MST: Th SLV: CH3 MODE: ACT (ON) OFST: 0 MXMD: MIX TRIM: OFF what going on with mine??? I had some weird gliching with my new servo today so I'm trying to make sure my TX is programed the right way.. thanks oh yeah....is there any problems or issues with taking the TX antenna off?? I only use the 4pk for my crawlers so I never get very far from my rx...and would like to take the antenna off the tx... Last edited by 53 willys; 09-12-2010 at 11:22 PM. |
09-13-2010, 08:17 AM | #1049 | |
You're not doing anything wrong. The (ON) or (OFF) part will toggle when you push the PS1 or PS2, after you program those two buttons. Just finish the programming steps and that will work itself out. Many of the crawlers remove the antenna fromt the TX. I would estimate you still get about 100 feet of range depending on your surroundings. Quote:
09-13-2010, 09:23 AM | #1050 |
Moderator Join Date: Jul 2007 Location: Texas baby!
09-13-2010, 11:00 AM | #1051 | ||
thanks for the help and info dudes | ||
09-14-2010, 11:12 AM | #1052 |
Newbie Join Date: Aug 2010 Location: World
Hai, Just see the wiring http://www.harleydesigns.com/images/wiring_4pk.jpg Will it work with dual BL ESC (Novak Goat + ballisitc 18.5T combos) ? Same setting as the pic ? No need to use dual BEC ? About the pic ... the ch. 2 & 3 will be used for esc 1 & 2, right ,..... and the 4th ch. will be used for BEC .... Also the cable from BEC to rx, so far the BEC from Novak goat only 2 cables (red and black), what the function of the 3rd cable (yellow color on the pic). Do I need to make this yellow cable on my Novak BEC ? Thanks |
09-14-2010, 12:08 PM | #1053 | |
You are correct, ESC's in channel 2 and 3. The BEC will go in channel 4. There is no need for the signal wire on the BEC. The Castle BEC's have this wire so that you can program it via the Castle Link cable. Quote:
09-14-2010, 01:41 PM | #1054 |
Rock Crawler Join Date: May 2009 Location: just north of BFE in SC
Sorry I don't have time to read the thread to probably find my answer. But I am using a 3pk with two esc right now but switching to the 4pk radio. Will the the R603 receiver work or do I need the R604 receiver to use the 4pk for its full capability. Thanks
09-14-2010, 02:06 PM | #1055 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
603 for 2.2, and 604 for super thats what i use
09-14-2010, 02:11 PM | #1056 |
| For a typical 2.2 MOA setup the 603 is fine. If you want cut brakes or a super class setup you will need the 604.
09-14-2010, 05:23 PM | #1057 |
ok thanks I didn't think it would matter but before I picked one up that had a 603 I wanted to be positive thanks |
09-15-2010, 02:38 AM | #1058 | |
But if I use the included Novak BEC in the package, will it work ? | |
09-15-2010, 07:25 AM | #1059 |
09-15-2010, 09:26 AM | #1060 | |
So I just need one BEC attached to the battery, right. The Novak BEC included in the package only rate for 3 amp output. (http://www.shopatron.com/products/mo....0.0.0?tp=spec) Do you think it's sufficient for SDX-901 (http://www.sanwa-denshi.co.jp/servo-01.html#SDX-901)... ? Rgds, | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
