10-01-2010, 09:21 AM | #1101 |
Ever since switching to the 4pk and a dual esc set-up I have noticed that when I dig on a vertical I get a slight rollback on my rear axle. my setup on my 5.5lb truck: 4pk HH 40t Epic motors Dual FXRs 850 mah 3s 45c lipos I run a "correct" gear mesh front and back. I know that tightening my mesh would probably help some, but is there anything else that I can do? I don't like running a tight gear mesh. This annoying rollback has cost me a few reverse penalties. |
10-01-2010, 09:23 AM | #1102 | |
Sounds like it's most likely a motor issue. I don't even run my FXR's at full drag brake because they lock so hard. As a motor wears it will have a less effective drag brake. Might want to hit up JRH and get his oppinion on this. Running a tighter mesh is not a method I ever suggest, seams like B.S. fix to me. Quote:
10-03-2010, 08:20 PM | #1103 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| xr10 setup
Just got my xr10, also, i just got my first futaba radio. It's the 4pk with with the r604fs receiver, could you please help me get the correct setup? i'll be running 2) fx-r esc's, 2) 35 turn brushed motors, cc10amp bec, hitec 7980th steering servo. I also plan to take advantage of the cutting brake when it comes out. I've been reading you'r threads but still not real clear on the setup, wiring schematics. Please help Thanks. |
10-03-2010, 10:32 PM | #1104 | |
10-04-2010, 08:16 AM | #1105 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
Thanks, you helped out a newb today. Thinking about getting this radio now.
10-04-2010, 08:17 AM | #1106 |
10-06-2010, 07:31 PM | #1107 |
Gold Star Baby! Join Date: Feb 2009 Location: Arizona
I know many have thanked you,but really your thread has been so helpful I stepped up from a DX3R and will not look back..now to find a cheap storage case...NO MO CASHOLA !!.. anyone getting a 4pk....this thread is a MUST !! now back to practicing OK, I do have a question..I looked first thru this thread till my eyes where bleeding.. ???..can you adjust the throttle expo and will it effect both escs ? I want it to be more responsive..Im running MM mini pros and have already ramped up the throttle curve.. Last edited by CRAWLER-DAD; 10-06-2010 at 07:34 PM. |
10-06-2010, 07:36 PM | #1108 | |
Try this one, it's about $24 http://www.rcmart.com/catalog/rc-tra...a-p-27927.html | |
10-06-2010, 07:45 PM | #1109 |
THX...that will work.. how about the ESC question..some help please |
10-06-2010, 08:32 PM | #1110 |
Sorry didn't see the edit. You need to add the expo in the ESC programming.
10-06-2010, 08:55 PM | #1111 |
Thank you for your time... |
10-07-2010, 04:24 PM | #1112 | |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
Nice sack. Out of stock. You know of any US dealers? Look on the Bay last night most were sold out Quote: | |
10-07-2010, 04:51 PM | #1113 |
10-09-2010, 06:54 AM | #1114 |
Newbie Join Date: Sep 2010 Location: Aurora, Indiana
I just got my xr10 the other week and got the chasis together. Its gonna be me first electronics build I've ever done on an rc, so I was nervous as could be trying to make sence of everything. This thread has been a life saver, now I know how to wire dual ESCs and program the 4pk. So now I can do it all right the first time |
10-10-2010, 01:02 PM | #1115 |
Hey Harley I am running dual fxr's in my xr-10 with a 4pks. I have the drag brake on the fxr's at 100% but on high traction sufaces it does'nt hold. Are there any adjustments in the 4pks that would help the drag brake?
10-10-2010, 04:36 PM | #1116 |
| There is nothing else your radio can do. Sounds like you need better motors.
10-10-2010, 04:43 PM | #1117 |
10-10-2010, 05:12 PM | #1118 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
I have 45t motors and for me heaver brush springs did help with braking...
10-10-2010, 06:00 PM | #1119 |
Newbie Join Date: Aug 2008 Location: Porto
| Help to put Punk 3 dig work in 4PK
Hello I have a AXIAL XR-10 with a NOVAK ROOSTER CRAWLER ESC and a PUNK 3 Dig. I only want steer in the front wheels. Can someone tell me how to put the 4PK so that I can use the Dig in the front or rear wheels? I donīt see any button on the 4PK that has 3 positions: 1 position -Activate the front did 2 position -OFF the front dig, so put the rig in 4WD 3 position -Activate rear dig Thank you |
10-10-2010, 06:18 PM | #1120 |
Moderator Join Date: Jul 2007 Location: Texas baby!
| Brood motors are good, but you need to keep an eye on the condition of the brushes and comm. If they are brand new, more than likely the brushes still need to seat in. If they are old, you probably need to cut the comm. Heavier brush springs help too.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
