Thread: 4PK Setups, Tips, Tricks and Help
Old 11-11-2010, 03:08 PM   #1201
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Originally Posted by MikeyBike View Post
Holy crap that was fast. I am using the 3 racing winch and you nailed it. I missed setting the RXSYS to normal. Damn you are a god with this radio! Thanks again for all the held over the last year.
Instant Email notification FTW You're welcome man.
Harley is offline   Reply With Quote
Old 11-11-2010, 03:13 PM   #1202
Stick King's Avatar
LMAO! Yea, U really are on point with your replies Josh
Stick King is offline   Reply With Quote
Old 11-14-2010, 08:08 PM   #1203
Default Good bye m2 hello fxr
traded my m2 dig for a fxr and just ordered a second one i cant wait
tofas4you is offline   Reply With Quote
Old 11-19-2010, 10:07 AM   #1204
Having recently purchased a 4PKS, I knew from this excellent thread of the programming difference for the programmable mixes and how the screen popup for Program Mix 2 blocked the mixing amount when in servo view. After setting up the radio per Harley’s video and using the Trim / Dial view as the workaround for the 4PKS, I really wanted to have both the servo view and mix amount viewable until getting comfortable with the radio operation to avoid getting “lost” in a mix while on course, expecially since I’m new to the dual esc world.
After experimenting with different settings I believe I have found an option for the 4PKS in order to have the servo view and the mix amount viewed concurrently without having to send the radio to Futaba for reprogramming.
The way in which the popup on the right side of the screen for Program Mix 1 and Program Mix 2 appears to work differently. The popup on the screen for Program Mix 1 On / Off would after popping up for roughly 3 seconds then disappear and the amount of mixing would be viewable as everyone had been accustomed to with the 4PK. Program Mix 2 for some reason when active has the popup which covers the mix amount and stays visible the entire time the mix is on.
Thus by changing Program Mix 1 to mix the throttle and channel 3 in place of Program Mix 2 the radio when using servo view provides a display like that of the 4PK.
Since I have not yet purchased an additional ESC and the tests above were based upon using the Servo view, can someone verify the above option works in actual operation?
The screenshot below shows the Program Mix 1 On / Off popup which disappears after roughly 3 seconds.
The screenshot below shows the radio with Program Mix 1 active, popup gone and the mixing percentage for the rear motor esc viewable on the right side of the screen, which is adjustable via the user selected DT.
The screenshot below shows the radio with Program Mix 2 active for rear dig.
bbeaty is offline   Reply With Quote
Old 11-19-2010, 10:11 AM   #1205
20K Club
Harley's Avatar
Looks like it works to me. I have not yet swapped my radio out to a 4PKS to try this however and even when I do I believe mine will already be reprogrammed. Good find
Old 11-19-2010, 10:13 AM   #1206
Looks like I have some reading to do. About to get on the 4pks bandwagon. Very informative thread for sure.
Szczerba is offline   Reply With Quote
Old 11-19-2010, 10:54 AM   #1207
Harley, Would you please break this down for us dummies?
I'd like to try this today but have a beer cloud in my brain from last night
Rig Rocker is offline   Reply With Quote
Old 11-22-2010, 01:58 AM   #1208
It works! Hell Yeah
Way to go BBeaty!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Old 11-22-2010, 11:45 AM   #1209
Rig Rocker: Thank you for the confirmation.
Old 11-22-2010, 12:49 PM   #1210
No problem And thank you again!
The mix display issue has been driving me crazy but I am 100% addicted to XR10 w/ 4PKS. Didn't know if I could handle losing my controller for a week or so to get the update
Old 11-22-2010, 10:33 PM   #1211
i cant seem to figure out how to set the rear esc on my 2.2. im running a 603 receiver and dual sidewinders.
storminator is offline   Reply With Quote
Old 11-22-2010, 10:41 PM   #1212
20K Club
Harley's Avatar
Having troubles following the video or?? I need more info to be able to help.
Old 11-23-2010, 09:54 AM   #1213
i followed the video, setup my radio, then went to power my crawler up and have no control of either esc. do i set them individually? all wiring is correct.
Old 11-23-2010, 10:02 AM   #1214
20K Club
Harley's Avatar
Are the graphs on the radio moving when you pull the trigger?
Old 11-23-2010, 10:04 AM   #1215
yep. everything lights up but just flashes.
Old 11-23-2010, 10:06 AM   #1216
20K Club
Harley's Avatar
Randy shoot me an email quick if you can. I'll give you a call or vise versa if you have the rig in front of you. Should be something simple.
Old 11-23-2010, 06:50 PM   #1217
sorry i didnt get back to you earlier, just got home. i found out that i managedd to cut the signal wires on accident when i was cutting some zip ties off thanks for the help though Harley
Old 11-23-2010, 07:50 PM   #1218
Harley when I purchased my 4pk used it didn't come with the hook for a neck strap...do you know how I can get one?
clarkrw3 is offline   Reply With Quote
Old 11-23-2010, 08:00 PM   #1219
Can someone please tell me if I will get my rear wheels to "lock" if I go to dual fxr's and set the drag brake high on the rear esc?
My current setup is just a single fxr and punk dig and I am relying on my magnets to lock the rear wheels and they dont hold as well as I would like them too. It is my understanding that if I go to dual esc's and set it up per Harley's guide the rear esc will stay ON and therefore use the actual drag brake feature of the esc when I do a dig. Thanks for any help with this.
Illeagle is offline   Reply With Quote
Old 11-23-2010, 10:04 PM   #1220
20K Club
Harley's Avatar
Well glad it got sorted out!
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html
Posted By For Type Date
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? This thread Refback 10-05-2011 06:51 AM
• Afficher le sujet - Mon nouveau joujou This thread Refback 10-05-2011 06:04 AM
