11-23-2010, 10:08 PM | #1221 |
11-23-2010, 10:11 PM | #1222 | |
11-24-2010, 02:57 PM | #1223 |
Quarry Creeper Join Date: Nov 2009 Location: East Greenville
11-24-2010, 02:58 PM | #1224 |
| Just unplugged, but you need to cover them. It isn't a very good idea to just leave live power wires flopping about the cab. |
11-24-2010, 03:06 PM | #1225 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
With the diagram you just posted what would be the maximum voltage you could set the bec at using a Futaba R614FF receiver? I am using a Hitec 7950 and wondered what that receiver can actually handle.
11-24-2010, 03:07 PM | #1226 |
| The RX can handle 7.4v at least. I can't recall the exact voltage but I think the limit is in the upper 8 volt range.
11-24-2010, 03:13 PM | #1227 |
so from the battery i need both connection points, can i run all three of those kinda like how a y harnes is set up but instead of just the ground to the two connectrs in a y harness i just attach the ground to another connector? Photos would be great of how you have yours set up Last edited by greenjeeper92; 11-24-2010 at 03:16 PM. |
11-24-2010, 03:15 PM | #1228 |
| WOW!! Thats awesome news, I am definitely going to bump the bec up to 7.2 range or so and squeeze some more juice out of that servo. Thanks alot for your quick response and continued dedication to this thread. My super and 2.2 would be lost w/o it!! |
11-24-2010, 03:15 PM | #1229 | |
There are hundreds of ways to wire it, do some searching in build threads to get some ideas. | |
11-24-2010, 03:16 PM | #1230 |
| No problem man |
11-24-2010, 03:19 PM | #1231 |
so all four power wires from escs to one connector?
11-24-2010, 03:20 PM | #1232 |
11-24-2010, 05:29 PM | #1233 | |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
| Quote: The BEC wires are soldered onto the esc tabs where the battery wires connect. That way its not part of the connection at the battery. Hope this helps! | |
11-28-2010, 02:39 AM | #1234 |
Newbie Join Date: Nov 2010 Location: miami
Hello, Im new into crawling... I bought an ax10 and 4pk.. I was wondering go 4 wheels sterring + DIG... Is that good/possible? if you have any electrical diagram would be nice!!
12-04-2010, 12:53 PM | #1235 |
Harley I have a couple questions for you that I could not find answers to on here or in the manual: I have my 4pk setup per your dual esc setup on my 2.2berg moa and I want to know if its possible to make one of the DT buttons work as the PS buttons do. For instance can I assign front dig which is now on PS1 to DT3 instead? I did not see a setting that would allow the DT buttons for just ON/OFF like the PS switches do. Also I wanted to know is there a way I can MAX out the rear motor epa? When I dial it down to slow the rear wheels down it works great and then when I go to dial it back up to 100% it actually will go up to 120% and the rears will spin faster. I know you just have to glance at the screen and watch for it to reach 100 but I would rather it STOP at 100 and I get the tone sound telling me its there so I dont have to watch the screen. Lastly would it be possible to put front AND rear dig both on one of the DT buttons? For instance when you have a punk dig you hit dt3 DOWN for rear dig and dt3 UP for front dig. Would it be possible to control the mixing of both on one up/down button? |
12-04-2010, 01:02 PM | #1236 | |
No you cannot use the DT buttons for dig. I suggest getting used to the PS buttons, they are actually a better setup and allow you to select and deselect dig much faster and more reliably. Most people ask this question when they switch to the 4PK but quickly learn the advantages of the setup later. You should also get used to the 120% rear percentage. Just like you back the rear motor down, there are times when you want to increase it. Being able to go to 120% is as important as being able to set it to 80%. Quote:
12-04-2010, 04:48 PM | #1237 |
Rock Crawler Join Date: Apr 2008 Location: Highlands Ranch, Co.
Mr. Awesome, i now have a PK4 & set it up with the setup from Whoodie & want to know do you have the THMOD set for 50/50 or 70/30? When i tried to set the speedo's (Sidewinders) in the 50/50 i could not get them to set on the brake side. On the 70/30 they set fine but the servo view shows a bit of bar to the brake side. If using the 50/50 should i set the EPA's on the brake side including the CH3 & CH4 down a bit to get the Sidewinders to see the brake end points? Thanks for your info in this tread as it really helped. Donnie |
12-04-2010, 04:55 PM | #1238 | |
12-04-2010, 05:07 PM | #1239 | |
Also if you have the rear locked & then go into reverse the rear no longer stays locked, it doesn't go "full throttle" but does not stay locked, any idea what that is or is it a normal function? | |
12-04-2010, 05:16 PM | #1240 | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
