12-06-2010, 11:18 AM | #1261 |
Moderator Join Date: Jul 2007 Location: Texas baby!
12-06-2010, 11:27 AM | #1262 | |
PMIX1 mst:ch3 slv:ch3 ofst:+100 PMIX2 mst:ch3 slv:ch3 ofst:-100 Using the "offset" feature of the mix menu is the key here. It allows the 3rd channel to go full throw in one direction with the push and hold of a button. I assume the 3PK has 2 mixes, right? Let me know if you need more detail, I can type it up tonight. | |
12-06-2010, 11:28 AM | #1263 |
Yup 3PK has 2 mixes IIRC. That sounds like it should work.
12-06-2010, 04:03 PM | #1264 |
Quarry Creeper Join Date: Sep 2008 Location: tucson
Ok did what you said on the mix set up do i need to change any of the buttons for this to work i set up SW2 and when i press it it will work but dosent go back to neutral it go to rear dig not working the way i wanted can you help |
12-06-2010, 08:25 PM | #1265 |
| Change the buttons from "ALT" to "NOR". That changes the behavior of the button from a "push on, push off" to a momentary type where you have to hold the button to keep it on.
12-06-2010, 09:10 PM | #1266 |
Did the bbeaty workaround for the 4pks. Rear value is displayed on the right as well as the servo view on the left. Good to go.
12-06-2010, 09:27 PM | #1267 |
| Did that it will do what I want front dig rear lock but when i let go it will go to rear dig front lock can't figure it out its got to be in the mixing but how to fix it i don't
12-07-2010, 02:13 PM | #1268 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
Interested in the 3pks. Can it run C2 mode and use the new 614 Rx?
12-07-2010, 03:56 PM | #1269 |
Pebble Pounder Join Date: Jan 2009 Location: italy
With the rx 614, can i use the cc BEC at 7,4v ?
12-07-2010, 04:22 PM | #1270 |
12-07-2010, 04:23 PM | #1271 |
12-07-2010, 04:23 PM | #1272 |
12-07-2010, 04:33 PM | #1273 |
Any idea what Im doing wrong or how to make this work
12-07-2010, 05:17 PM | #1274 |
12-07-2010, 05:20 PM | #1275 |
| I'm guessing you haven't done exactly as whoodie posted before. Reread his posts and if you can't figure it out post your screens and we can probably fix it. Reread his instructions first though.
12-07-2010, 09:31 PM | #1276 |
Ok i read it again can't get it to work here is the pics you asked for http://i876.photobucket.com/albums/a...2-07195226.jpg Last edited by whoodie; 12-08-2010 at 07:31 AM. |
12-07-2010, 09:37 PM | #1277 |
Maybe set the down value to 0. I would have to read through what Whoodie posted more as I haven't looked into this extensively yet.
12-07-2010, 10:13 PM | #1278 |
Pebble Pounder Join Date: Nov 2008 Location: tacoma
dang i keep reading and switching stuff around both from jdawg53 and herley0706 posts and well.............................................. ............................... my radio must be really messed up o well guess ill send it in and get the software update and see where it goes from there .............................................. |
12-08-2010, 06:18 AM | #1279 | |
12-08-2010, 07:33 AM | #1280 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
