11-06-2011, 09:04 PM | #1641 | |
Rock Crawler Join Date: Apr 2008 Location: Calgary
I first asked about this after messing around with it for about 12 hours in total. I want my dig switches to be the same as my XR10 but want linear rear steer, same and opposite. I still haven't received a good answer about this and at the time Harley didn't have his 4PKS yet. Does anyone have any idea's on how to use the 4ws set up the the 4PKS has? Quote:
11-07-2011, 07:28 AM | #1642 |
I've got my PKS now, I'll try and look at this tonight.
11-07-2011, 08:08 AM | #1643 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
I don't know if it matters but I'm running a pk not a pks....
11-07-2011, 08:15 AM | #1644 |
11-07-2011, 09:42 AM | #1645 |
11-07-2011, 09:54 AM | #1646 |
11-09-2011, 05:51 PM | #1647 |
so for some reason I'm having one hell of a time setting up my super controls...I'm hoping you can help? here is what I want... ps1=front ESC on/off ps2=rear esc on/off dt3=front esc mixing at 5 increments dt2=rear steer in 50 increments dl2=rear steer in 20 increments front servo is in ch 1 front esc is in ch 2 rear esc is in ch 3 rear servo in ch 4 I cant seem to figure what im doing wrong but the mixing is not working on the esc....I can go +100 or -100 and the esc never changes speed...I have the esc wired what settings do I need to apply to make this work?? or am I still trying to make the 4pk do something it's not capable of??? |
11-09-2011, 05:54 PM | #1648 | |
11-09-2011, 06:18 PM | #1649 |
Really? I mix my front on my 2.2 with out any issues... I'm so confused... |
11-09-2011, 07:06 PM | #1650 |
11-09-2011, 07:57 PM | #1651 |
11-09-2011, 08:10 PM | #1652 |
11-09-2011, 08:54 PM | #1653 |
Man, I really apologize if this has been covered 1,000x. I searched this thread and tried to browse 83 pages, but I am two hours into finding what I think should be a simple answer. I have dual esc, watched the video and have everything setup per the video. I do not want the PS buttons for dig. I would really like my DT3 to run my dig just like my 4pl did (front dig, 4wd, rear dig). Help? Edit: I think I found the answer and I am not sure I like it. I think I could get used to using the PS2 but I loathe using my thumb to dig. I really, really hope this is not the case. If it is, anybody need a good used radio? LOL Last edited by Erik D_lux; 11-09-2011 at 10:49 PM. |
11-10-2011, 06:31 AM | #1654 | |
11-10-2011, 08:22 AM | #1655 | |
Pebble Pounder Join Date: Mar 2011 Location: Aurora, CO
By any chance have you had a chance to mess with this? I still haven't found any additional mixes on. It just feels like channel 3 is slaved to channel 4 only when it's active. Marcus | |
11-10-2011, 09:01 AM | #1656 |
Sorry, I'll get to that. Thanks for the reminder.
11-10-2011, 09:41 AM | #1657 |
So I went back through and set everything up just like your vid....it's working great right now...but I gotta ask you guys.. Don't you ever feel like you need to overdrive the rear esc more then 120%?? When my rig is on a climb and all the weight transfers to the rear and clod stall comes in 120% does not make the stall go away the front still spins fast and the rear still stalls..... I just feel like turning down the front esc would work much better to get both axles moving at the same time.... Can't believe I'm the only one who feels this way? |
11-10-2011, 09:49 AM | #1658 |
If I plug the rear esc into channel 2 and the front esc into chan 3 would I be able to mix the front instead of the rear with out issues??
11-10-2011, 10:25 AM | #1659 |
Yes. I see people using less than 80% rear much more often then needing more overdrive. Never had any driver want to run that. I dip down to 60-70 percent all the time.
11-10-2011, 10:38 AM | #1660 |
Lol I guess I'm just set in my old school ways....I just can't get used to turning the rear esc down and up to get it to drive how I want... So that "yes" was a yes that I can swap esc channels and mix how I'm used to mixing with out issues? Thanks for dealing with my weird set up qestions... |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
