01-29-2013, 07:28 PM | #1781 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: 4PK Setups, Tips, Tricks and Help
Well, that didn't change anything. I got the 3rd Chanel to be at zero instead of +100 and it still spools. Not sure what to do now |
02-06-2013, 10:42 PM | #1782 |
Ok...never did get the original model set up to work....but changed the model to a completely virgin model...problem went away Live and learn |
02-11-2013, 04:37 PM | #1783 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
Hello Harley Today I was showing a friend how he could bind his 4pk to my truck sence I am lefty and he is right handed..after we were finished I noticed my truck will now coast when throttle is at neutral...if I go from forward to reverse instead of a solid stop it will coast.....never had this happen before... Did a setting change or what....if you can help with this please let me know thanks .... |
02-11-2013, 04:43 PM | #1784 | |
| Re: 4PK Setups, Tips, Tricks and Help Quote:
02-11-2013, 04:58 PM | #1785 |
I have 2 FXR ESC...I am not sure I understand what you mean by changing The end points on them....do you mean the EPA(ATV) on the 4pk they are at: TH FRD: 100 100: BRK.... |
02-11-2013, 05:13 PM | #1786 |
| Re: 4PK Setups, Tips, Tricks and Help |
02-11-2013, 05:15 PM | #1787 |
Harley I fixed it it was my drag brake setting on the FXR. thanks for your fast response.....strange they both changed....oh we'll they are working now..... |
02-11-2013, 09:17 PM | #1788 | |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
I need to get another RX for my SCTE. I tried to order a R603FF from tower from their "scratch and dent" section but it was DOA and will be going back tomorrow. So I would like to go 4 channel to replace it(since they are smaller anyway). Last edited by 65BAJA; 02-11-2013 at 09:20 PM. | |
02-22-2013, 09:45 PM | #1789 |
Pebble Pounder Join Date: Apr 2011 Location: australia
How do I turn channel 3 into a 3 position switch ( forward/off/reverse ) using PS1 on my 4PK. I want to use it for winch controller . Thanks . I can1t get it . |
02-22-2013, 09:47 PM | #1790 |
02-22-2013, 10:31 PM | #1791 |
Is there any way of setting up something on the 4PK to act as a three way switch?
02-22-2013, 10:33 PM | #1792 |
02-22-2013, 10:43 PM | #1793 |
Thanks Harley. Used DT 1 prportionally in increments of 20. Exactly how I wanted it to work . |
02-24-2013, 07:33 PM | #1794 |
Newbie Join Date: Aug 2011 Location: Boise
So I bought a 4pk used from a friend and it worked fine for my scaler up until today. I ran our first two courses firat one was 210 gates and the second was 100 but when I plugged in to run the third course my rs speed control showed the last three lights on it. Is this a radio issue or something else? If I'm in the wrong section let me know. |
02-24-2013, 10:50 PM | #1795 | |
02-25-2013, 08:27 PM | #1796 |
| Is this in the speed control or the radio. I tried to reset the speed control and it picked up neutral and forward but not reverse. I appreciate the help.
02-25-2013, 08:29 PM | #1797 |
02-25-2013, 08:59 PM | #1798 |
I will give it a try as soon as I get put back together. Hopefully it that fixes it. Thanks again.
03-16-2013, 06:57 PM | #1799 |
Harley one quick ? Will this bind to my 4pk.....FUTABA R2106GF 2.4G SFHSS Micro 6Ch Rx Thanks tom |
03-16-2013, 07:06 PM | #1800 |
Pebble Pounder Join Date: May 2005 Location: Long Island NY
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
