07-30-2013, 11:21 PM | #1821 |
Newbie Join Date: Jan 2013 Location: Los Angeles
| Re: 4PK Setups, Tips, Tricks and Help
I was looking for instruction on 3rd channel operation for a servo working the 2 speed tranny. I've burned a couple servos not knowing how to adjust end point, luckily they were just cheapies. Any and all help would be appreciated. I have a 4pk radio. Thanks again
07-30-2013, 11:45 PM | #1822 | |
| Re: 4PK Setups, Tips, Tricks and Help Quote:
Select any of the DT switches you want Select the channel that you have the servo plugged into Set the value to 2P Go to the EPA Menu Back the values down in each direction until your servo doesn't buzz when in gear. | |
08-02-2013, 02:21 PM | #1823 |
Thanks for the help.
08-07-2013, 09:14 AM | #1824 |
Newbie Join Date: Aug 2013 Location: Belgium
| Re: 4PK Setups, Tips, Tricks and Help there's something strange with this post, I guess it' too old: I can only see a picture of a PKS, but not the movie if I click on it; the only way for me to see the movie is to reply to this post, so I can see the photo bucket-link (URL) where the movie is; I then have to copy that URL and paste it into another (Safari)tab, but then again, I can't download the file... could you please send me this movie via email, as well as the movie in which you program the 3PSK (or 4PSK on 3 channels). As I've just ordered my 4PKS-R and will order my XR10 only next month I want to be sure to have this marvelous setup movies at hand... Superb Thanks in advance a crawlerfanatic to be |
08-07-2013, 11:48 AM | #1825 | |
08-08-2013, 01:58 AM | #1826 | |
"When the 3rd CH was set to ACT at Brake Mixing (p.74) or when Gyro Mixing (p.92) is used, 4WS mixing cannot be used." and p90 (dual ESC mixing): "When 4th CH was set at ACT at Brake Mixing (p.74) or when CPS-1 Mixing (p.94) is used, Dual ESC Mixing cannot be used", so if I meet these requirements, programming 4WS AND DIG should be straightforward (no tricks required). If it turns out otherwise, I'll let you know... Thanks nonetheless A little bit off-topic: all my Local Hobby Stores (Belgium) tell me the XR10 is not available anymore (from the distributor). Is it discontinued and/or will there be a successor soon? | |
08-08-2013, 01:29 PM | #1827 |
Newbie Join Date: Aug 2013 Location: Batam
hi, i have a 4pk with r604 receivers, been using it over a year. Last Night my brother played with it and forgot to turn off my rc. Next day when i tried to siwtch on after i changed my battery, my rx turns solid red. I thought need to rebinding. try to bind, whenever i turn on my rx, it turns solid red and when i pressed the swith on rx, it blinks red few times and back to solid red. I have tried few ways like, to turn on tx first then rx then press the switch, still same. it switch on my tx then press the swith on rx and turn on my rx..still same i also tried to move away from any wifi..also same.. tx mode C1 or C2..both same... NO GREEN LED SHOWS UP AT ALL...really sad... Can anyone help me...i am in Indonesia..no futaba service centre here... Really thanks any help... |
08-08-2013, 01:32 PM | #1828 | |
08-08-2013, 01:37 PM | #1829 |
| Re: 4PK Setups, Tips, Tricks and Help Thanks for your quick reply....i tried that..but still same problem....because i read at manual, that need to be close to each other..i tried to touch them..but still no result..same solid red..few red blink and back to solid red... |
08-08-2013, 01:39 PM | #1830 |
| Re: 4PK Setups, Tips, Tricks and Help And the display shows C2 in the bottom right corner?
08-08-2013, 01:41 PM | #1831 |
| Re: 4PK Setups, Tips, Tricks and Help |
08-08-2013, 01:44 PM | #1832 |
| Re: 4PK Setups, Tips, Tricks and Help Hmmm, well it's not sounding good. I would suggest double checking your batteries voltage in both the radio and truck, cycling the power (making sure the radio is turned to on and not display only) and trying to rebind one more time with the TX antenna touching the body of the RX. That's about all I can suggest |
08-08-2013, 01:53 PM | #1833 | |
08-08-2013, 01:56 PM | #1834 | |
You can power the RX from ANY channel slot, it makes no difference. The only slot that is not tied into the power traces of the RX are the DSC port. I can't say I am familiar with that Hobbywing piece. | |
08-08-2013, 02:25 PM | #1835 | |
08-10-2013, 12:42 PM | #1836 |
I wanna be Dave Join Date: Dec 2008 Location: ?
I got a new 604fs when trying to bind it to the truck it just flashes green? anyone have this issue? thanks |
08-10-2013, 03:54 PM | #1837 |
08-10-2013, 04:37 PM | #1838 |
02-23-2014, 12:38 AM | #1839 |
Quarry Creeper Join Date: Apr 2013 Location: Norway
In lane one in Spain,the rig suddenly started to run on its own. The throttle on my Pks suddenly gave som throttle when it was supposed to be in neutral. Had no chance to drive with this.Then after 10 minutes it was ok again and worked fine the rest weekend. Now,when I`m home it happens again on another car I have. Hitting the throttle a few times,then its ok again.But I can`t use it like this. Have anybody else had troubles like this? Is it the pot meter or something on the throttle making this? Holt |
04-28-2018, 11:33 AM | #1840 |
Rock Crawler Join Date: Nov 2014 Location: Dells
Finally broke down and am going to use my 4kp in my trail truck... I only have TFR4 RXs and a few 8ch HK specials for my airplanes. They all only work in C1 mode. I can't get ch4 to work at all , no signal is output on it. Is it a function of the radio where ch4 only works in c2 and not c1, or am I missing something? |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
