10-01-2008, 08:59 AM | #1 |
Quarry Creeper Join Date: Sep 2008 Location: sterling VA
| dual mamba max esc wiring question
hi,i have a problem with the wiring of my super, the question is how do i wire 2 mamba max to take 1 battery, ill be using a 3s lipo and also will the mamba max take a brushed mtor without programming it? thanks, id like to find out cause ive been itching to try my new super, thanks again fellas!
10-01-2008, 09:07 AM | #2 |
You just need to run both positives from the ESCs to the positive on your connector and both negatives from the ESCs to the negative on your connector. Depending on the connector, it might be easier to solder the leads from the ESCs to a single piece of wire and attach that to the connector. Also, IIRC, the MM comes setup for Brushless from the factory. |
10-01-2008, 09:30 AM | #3 |
Quarry Creeper Join Date: Jan 2007 Location: L.I.
10-01-2008, 10:50 AM | #4 |
yup, i was just gonna make 1 of those, thanks. and what about the esc can i use my programmer to switch it from brushless to brushed?
10-01-2008, 11:01 AM | #5 |
Yep, with the castle link hardware and software, you can easily switch it to brushed. The program is extremely simple to use.
10-01-2008, 01:36 PM | #6 |
