Thread: Battery dies.......truck keeps going?
Old 11-28-2008, 10:30 AM   #1
Default Battery dies.......truck keeps going?
ok so this started fairly recently. ax10, tekin fxr. when by battery dumps the truck keeps going. Its slow so its not a huge deal but its def a PITA......is there a setting i could look at?
Deezul is offline   Reply With Quote
Old 11-28-2008, 09:08 PM   #2
Which radio do you use? If you have a Spektrum or some other radio that uses failsafe it may be set to the slow crawl that you're seeing. When you're battery gets low it could go into failsafe and cut you out of the loop. Try it with a full battery and turn off your TX, if it takes off that's prolly your problem. Just re-bind which will reset the failsafe (don't give any throttle inputs while binding).
jakepkoe is offline   Reply With Quote
