| | #1 |
| RCC Addict Join Date: Mar 2008 Location: lackawaxen, pike county. PA
| ok reading some threads on wiring dia and seeing there are a bunch of ways to do this.... ![]() ![]() ![]() i see that there maybe a need for some rx plugs to plug the BEC into the steering servo and such....where does one find these plugs at....which way works the best....i just soldered my BEC leads to a female and male deans plugs like this.... ![]() so that i can use it as needed instead of unsoldering it on and off my ESC wires....right now i'm just waiting on my baby shark tube bender i pre-paid on the pre-order to start my build....now i'm just buttoning up the wiring as i need to....so which wiring dia have people used and works the best .... |
| Sponsored Links | |
| | #2 |
| I'm Dracula, Bitch. ![]() Join Date: Sep 2005 Location: Houston, TX
| | #3 |
| | #4 |
| Quarry Creeper Join Date: Sep 2008 Location: sterling VA
| | #5 |
| Gavyn is my BFFL ![]() Join Date: Feb 2007 Location: hunting pandas
| take the yellow wire out of the bec |
| | #6 |
| Back in the WATER! ![]() Join Date: Mar 2008 Location: Pacific Ocean
| It's likely because the bind plug and BEC are the same on your RX. So you unpluged the BEC to bind. When you did that you no longer our providing power to the RX which is needed to bind. This is because the red wire is disconnected on the ESC. So what you can do is unplug the steering or the Aux servo and plug your BEC into that open outlet. This should provide power to the RX. Then plug the bind plug in the Bind/Batt port and bind as normal. |
| | #7 | |
| Quote: I created these diagrams and I no longer use either of these methods. I was experiencing surges because my Dig was drawing too much power as I was using a full size digital servo. Using CC's instructions is working much better! | |
| | #8 |
| | #9 |
| Pebble Pounder Join Date: Sep 2008 Location: Scotland Neck
| Welllllllll, when all else fails read the instructions!!!!! |
| Thread Tools | |
| Display Modes | |
