Thread: FXR question
Old 11-30-2008, 05:53 AM   #1
Default FXR question
I am in the process of wiring my Berg. I am running dual FXRs with Nomadio radio gear.
If I run both red wires from the FXRs into the receiver, does that double my volts ?
Will it work at all ?
Will I fry something ?
Will it negate the need for a BEC ?
Thanks from an electronics n00b
Shorty40 is offline   Reply With Quote
Old 11-30-2008, 03:04 PM   #2
I don't think it'll double to volts but double the BEC amp capacity, just like running two BECs in parallel, because both ESC power wires will be supplying the Rx power rail in parallel.
I never tried it on mine before installing the external BEC though, maybe someone who has actually given it go can confirm. It certainly shouldn't cause any glitching through the React though ;)
LincolnBlack is offline   Reply With Quote
Old 11-30-2008, 11:59 PM   #3
Sorry Linc, that's what I meant.........double the BEC, not the volts.
I just want to know if it will work before Benno does it.
Old 12-01-2008, 03:22 PM   #4
I'll give it a try for you this arvo if you like, see what happens!
Old 12-08-2008, 01:08 PM   #5
have you gotten any feedbacks on increasing the volts on the BEC
slip408 is offline   Reply With Quote
