Thread: I need the truth.
Old 11-30-2008, 05:58 PM   #1
Exclamation I need the truth.
Is brushless motors water proof. the guy at the hobby store said that they are not. and this site said they are.
crawlking93 is offline   Reply With Quote
Old 11-30-2008, 06:11 PM   #2
hitman46mod's Avatar
"You can't handle the truth!"
Most Brushless motors say not recommended for water use. So where did you read they were? Besides you want to drop $50 bucks or $25 bucks for something you are going to end up ruining.
hitman46mod is offline   Reply With Quote
Old 11-30-2008, 06:11 PM   #3
None of the motors are waterproof. The BL will tolerate water better than the brushed. All water has some form of impurity and or some level of acidity. This is hostile to the brushes and the commutator. The bearings in both types will suffer water damage from the dirt and acid in the water. Neither one is likely to explode on contact. The TRUTH is if you run them in water they will eventually fail.
One-eyed Jack is offline   Reply With Quote
Old 11-30-2008, 09:14 PM   #4
cherokee95's Avatar
brushless will run just fine in water..........doesn't mean you should do it. Biggest thing is the tolerances in bl motors are so tight any particulate matter that gets in the case will usually lock them up pretty quick. Brushed will ware faster but with a little maintenance they will last a long time, I have been running the same integy 55t in one of my rigs for three years and submerged it almost every time ( we like to play in the water ) it's been out. Clean and lube it every time, new brushes once in a while and it just keeps on keepin' on.
cherokee95 is offline   Reply With Quote
Old 11-30-2008, 11:27 PM   #5
Brushless will run in water BUT only the outrunners. I wouldn't ever try to run an inrunner epecially a sensored one in water.
bigflex is offline   Reply With Quote
Old 11-30-2008, 11:34 PM   #6
Give me ANY motor, and I can destroy it with water.
Robb is offline   Reply With Quote
Old 12-01-2008, 07:35 AM   #7
Gold Star Baby!
rottenbelly's Avatar
[IMG]Thank eeepee for this display of breaking in a brushed motor. I can destroy them with water or sand but i cant afford it so i try to take care of them .
rottenbelly is offline   Reply With Quote
Old 12-01-2008, 12:29 PM   #8
Paypal....arghhhh!!
cartronicshn's Avatar
The truth is out there......
cartronicshn is offline   Reply With Quote
Old 12-01-2008, 12:31 PM   #9
Clean water and real world water are different things.
Old 12-01-2008, 12:31 PM   #10
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Inrunners are fine in water too, but sensored motors don't like it as the hall effect sensors get all screwy.
JohnRobHolmes is offline   Reply With Quote
