Thread: esc
Old 12-01-2008, 06:15 PM   #1
Default esc
i have a sidewinder micro esc that im going to be running in my ax10 with a intergy 55t. i manualy programed it for brushed motors. now when i pull the throttle the green light comes on but nothing happens, same thing when i go in reverse, the red light comes on but nothing happens. the servo works fine though. i ordered a castle link if that helps. can you tell me what to do???
Mr.Cool is offline   Reply With Quote
Old 12-01-2008, 06:26 PM   #2
Rockcrawler's Avatar
Put a meter on the motor leads to see if its getting power.
Rockcrawler is offline   Reply With Quote
Old 12-01-2008, 06:32 PM   #3
i dont have a volt meter
Old 12-01-2008, 06:39 PM   #4
if it isnt getting power what should i do? and if it is getting power what should i do?
Old 12-01-2008, 06:47 PM   #5
you could get a small light bulb with 2 wire leads coming off of it to test for power too.... hook it to the motor leads and if it lights up when you accelerate its getting power!
flybynighter is offline   Reply With Quote
