Thread: Help Urgent lipo question
Old 12-02-2008, 09:16 PM   #1
toy4crawlin's Avatar
Default Help Urgent lipo question
IS it safe to connect a Thunder power 2s 8000 lipo IN Series with a Max amps 2s 8000 ?
Looking at buying a 1 yr old used Thunder p lipo , is that risky and is it ok to connect to a new or used Max amps ?
Thanks
toy4crawlin is offline   Reply With Quote
Old 12-02-2008, 09:28 PM   #2
just read in battery section
that thes batteries were recommended and tested, but no mention of max amps.
a. Pollyquest
b. Polly RC
c. Thunder Power
d. Hyperion
e. Elite
Old 12-02-2008, 09:35 PM   #3
Max amps bats are fine. But if i was goin to run in series or parallel i would start with 2 new packs and charge run them together. Remember that lipo has a shelf life and i personaly would not buy a year old pack no matter who made it inless it is dirt cheap.
ubbb69 is offline   Reply With Quote
Old 12-02-2008, 09:38 PM   #4
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Don't mix and match cells in series. Parallel you can get away with as long as the packs are the same voltage.
JohnRobHolmes is offline   Reply With Quote
Old 12-02-2008, 09:46 PM   #5
good to know
Whats the shelf life
he said it has been cycled a handful of times. and still runs great, giving me 3 days to return it.
I'm on a tight budget, any recommendations ?
It's a Thunder power 2s 8000 for $50. retail $175.
Problem is I need Two of these.
Old 12-02-2008, 09:53 PM   #6
3 years is the shelf life. Typical lipo will lose 20% capacity after 30 cycles if ran at continous discharge every time. If ran at lower rates, 300 cycles is easy to hit.
Old 12-03-2008, 11:39 AM   #7
Man that last post was a good one John. LOL I saved the e-mail notification. That was simply classic. Sorry to see you deleted them all. I was hoping someone could have learned from it.
Best regards,
Jason
JAM MaxAmps.com is offline   Reply With Quote
Old 12-03-2008, 11:53 AM   #8
Not much tech in it, so I figured I would clean up before it got out of hand. Some learning needs to be done for sure.
