Thread: Shutdown
Old 12-03-2008, 05:01 AM   #1
I'm Dracula, Bitch.
JeremyH's Avatar
Default Shutdown
I just finished building a scaler for my Dad for Christmas and have been running it outside to get some of the bugs out and there is one that is puzzling me. I built a 7 Cell 1600mAh batteries and stuck it in the truck. It will run perfectly for about 7 minutes then just stop and I only get response from the steering (and the LEDs still work). At first, I thought it was the low rating of the cells, so I built up a 7 Cell 4500mAh pack and it did the same thing in about the same amount of time. Is the ESC shutting down for some reason? I looked up the specs of this controller before I used it and everything seems to be within it's capabilities.
Specs:
Traxxas XL5 Waterproof ESC
Integy 55T w/~17T pinion
7C 1600mAh Battery
TwistedXT LED system connected to Rx
Towerpro servo
Have been using a Hyperion 606I for charging duties
I noticed that after the truck stopped running, if I put the pack (1600 mAh) back on the charger, the starting voltage is ~9.5V.
Here is the build thread of the truck if that will help any:
Dad's Scale Truck
Thanks!
Jeremy
JeremyH is offline   Reply With Quote
Old 12-03-2008, 06:24 AM   #2
666
666's Avatar
I bet you are running a Spektrum?
666 is offline   Reply With Quote
Old 12-03-2008, 06:29 AM   #3
I'm Dracula, Bitch.
JeremyH's Avatar
Opps....sorry forgot to list the Rx and TX.
Tx=TQ2
Rx=Traxxas 3 channel
Old 12-03-2008, 06:57 AM   #4
Rockcrawler's Avatar
How many mah are you putting back into the battery?
Rockcrawler is offline   Reply With Quote
Old 12-03-2008, 07:12 AM   #5
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I would say the BEC is getting over amped, but then you wouldn't have steering input available. Maybe the xl-5 is overheating from partial throttle use?
JohnRobHolmes is offline   Reply With Quote
Old 12-03-2008, 07:32 AM   #6
I'm Dracula, Bitch.
JeremyH's Avatar
Hummm.....I didnt feel the ESC for temp. I'll run it this evening and check the temp with my digital temp gun. Although, I have mostly been running it at full throttle...
Rockcrawler, I'll pay attention to the total input current when I charge it after running it this evening. I assumed, though, that it wasnt a problem with the battery since I had the same issue with a different pack. I have had no charging issues with my 606I....it has been charging my other batteries (mostly LiPo) without issue.
Old 12-03-2008, 08:13 AM   #7
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
I'll bet it's a thermal shut down because it comes back to life it's not permanent. Have you let it sit for awhile and re-connect the same battery?
Stormin2u is offline   Reply With Quote
Old 12-03-2008, 08:30 AM   #8
I'm Dracula, Bitch.
JeremyH's Avatar
Using the same battery with the same charge that it had when it shut down? I have run it many times after it shuts down, but I usually recharge the battery.
Also, when it shuts down, only the motor is affected. The motor stops on a dime (unlike a dying battery), however the steering and LEDs continue to function properly (as expected with a dying battery).
I will be getting a Sidewinder in a trade that I might just toss into this truck. I was hoping to keep the electronics simple (so that if it needs to be reprogrammed, the process is simple) and somewhat waterproof (since I cant control where he drives this thing), but I guess that just isnt in the cards for this truck.
Old 12-03-2008, 08:36 AM   #9
Gold Star Baby!
Stormin2u's Avatar
I find it hard to believe it's the battery it has to be the ESC or the motor. Let us know what happens tonight it's a interesting problem.
Old 12-03-2008, 08:53 AM   #10
I'm Dracula, Bitch.
JeremyH's Avatar
I was just given a suggestion to check for a stuck brush. This sounds like a very possible solution to the problem....as the motor is not new. I ran it in another crawler for quite some time before I put it in this truck.
Old 12-03-2008, 03:49 PM   #11
It is most likely the ESC shutting down on a Lipo cutoff. The Traxxas esc that I have run have the Lipo cutoff as a default setting. Check the esc manual and or the settings on the esc.
One-eyed Jack is offline   Reply With Quote
Old 12-03-2008, 04:51 PM   #12
I'm Dracula, Bitch.
JeremyH's Avatar
I don't think this one can handle a Lipo, so I don't think there is a voltage cutoff. If I am wrong, someone correct me!
Old 12-03-2008, 05:16 PM   #13
stuck brush sounds like a good possiblity actually, don't know why that didn't occur to me.
Old 12-03-2008, 05:46 PM   #14
I'm Dracula, Bitch.
JeremyH's Avatar
Ok, I think Ken, mudboger07, who sent me the suggestion through PM that it might be a stuck brush, nailed it! I swapped out the brushes and have been running this thing for more than 1/2 hour and everything seems to be going well.
Thanks for all of the help guys!
Old 12-03-2008, 07:27 PM   #15
I'm Dracula, Bitch.
JeremyH's Avatar
Ok, this thing is still going strong....those brushes must have been quite bad....I notice a lot less friction in the motor now. At full throttle it used to stop within 6" after letting go of the throttle, now it rolls for about 18".
Old 12-03-2008, 07:36 PM   #16
Gold Star Baby!
Stormin2u's Avatar
That's good news and handy information sure hate to see a Christmas gift have a problem.
I'm sure you dad will be surprised and delighted.
Old 12-03-2008, 07:45 PM   #17
I'm Dracula, Bitch.
JeremyH's Avatar
Haha....yeah, I cant wait to give it to him! He is gonna love this truck!
Old 12-04-2008, 07:37 PM   #18
glad i could help......it dont happen very often.....lol. anyways next time i get to tx well have to go crawlin 1:1....
mudboger07 is offline   Reply With Quote
Old 12-04-2008, 08:26 PM   #19
I'm Dracula, Bitch.
JeremyH's Avatar
Sounds like a deal! I'll buy the beer!
Old 12-04-2008, 10:07 PM   #20
Gold Star Baby!
Stormin2u's Avatar
Yeah it's going to be special to him.
