Thread: servos
Old 01-30-2004, 11:55 AM   #1
Default servos
got a q's got some jr servos for my x-factor which is hitec radio gear and 75 mhz when you plug them in they freak out
but if you plug them in to my t-maxx which is 27mhz they are fine i thought all servos were compatible?
dheavychevy is offline   Reply With Quote
Old 01-30-2004, 04:23 PM   #2
Default Re: servos
if i buy a t-maxx reciver and radio will the stock hitec servos for throttle and reverse still work
Old 02-01-2004, 05:09 PM   #3
Highmark's Avatar
Default Re: servos
Most are-may be that you're servo's have a diffrent plug then the Hitech reciever accepts. Also make sure you're useing new bats in both radios. You might also need to replace the crystals.
Highmark is offline   Reply With Quote
Old 02-02-2004, 10:41 AM   #4
Default Re: servos
I'm not sure what's up with the JR servos. First of all, I think their servos suck! They don't last long and they are over priced. When I plug my JR servos into some receivers, they freak out too. Not sure what the deal is but for some reason the JR servos have interferance with some radio gear. I do not use JR servos anymore. The radios, on the other hand, are great!!!
DirkDigler is offline   Reply With Quote
Old 02-02-2004, 04:47 PM   #5
Default Re: servos
what servos do you think are good buys cause i put t-maxx radio gear in just remote and reciver and it works great but like oyu said i think the one servo is weak already plus i need new throttle and reverse servos
and advice?
one more thing how can i get more run time out of my reciver batts?
Old 02-02-2004, 04:52 PM   #6
Default Re: servos
I still think the Hitec 645 servos are a great value. You can get the same servo for even cheaper with the Hobbico name on it. XTM's new 175oz servo is probably the best buy on the market but they are impossible to get right now.
As for receiver batts, just get the highest mah capacity anyone makes. that's the best you can do. Run stock servos for throttle and brake. High torque servos will just rob the juice and you will not really benefit from them in that location. Just use them for steering!
Old 02-02-2004, 04:56 PM   #7
Default Re: servos
that was wicked quick thanks for the advice
Old 02-02-2004, 04:58 PM   #8
Default Re: servos
Yo Joe!!!!
Old 02-02-2004, 06:25 PM   #9
Highmark's Avatar
Default Re: servos
I'm going to try the new XTM servo from the mammoths in my Bruz-they have 175 oz/in of tourqe @ 4V and are only $30 :o
Old 02-02-2004, 06:45 PM   #10
Default Re: servos
sweet thats the next set cause i have 2 jrs at 142 oz at 6 and with 4 wheel steering they have a little trouble with the hot bodies 7 inch tires
Old 02-03-2004, 09:52 AM   #11
Default Re: servos
Yes,
the XTM servos are about 205 oz. of torque with 6 volts. Pretty impressive for only $34!!!
I just wonder about their life span. I guess for that price, who cares.....as long as they last for more than a few months....they are worth it!
Old 02-20-2004, 05:04 PM   #12
TCS Team Manager
Fishmaxx's Avatar
Default Re: servos
Where are you guys finding the xtm servos?
Fishmaxx is online now   Reply With Quote
Old 02-24-2004, 10:24 PM   #13
Default Re: servos
8O 8O 8O man thats cheap! right now i got tower hobbies ghigh torque servos and they suck! they arent strong enough at al, any rock i go up to it just turns the servo on me .
Dontstall_Rockcrawl is offline   Reply With Quote
Old 03-02-2004, 04:20 PM   #14
Colt Python/SR9c
TwistedCreations's Avatar
Default Re: servos
so where are you guys finding these XTM servos?? i have looked around and cant seem to find them
TwistedCreations is offline   Reply With Quote
Old 03-03-2004, 06:23 PM   #15
Default Re: servos
you can get them at hobbypeople.net the part number is 145760 thats for the torque punisher
Old 03-06-2004, 07:02 AM   #16
Nomercy's Avatar
Default Re: servos
what dos everyone use for servo savers, i i get aginst a rock or something id still like to beable to turn the tire, but not burn up my srvos.
Nomercy is offline   Reply With Quote
Old 03-07-2004, 12:40 AM   #17
Default Re: servos
Does anyone know what the spline is? What I mean is what servo saver spline will work. Is it Futaba, Hitec, ect?
NeoSlayer888 is offline   Reply With Quote
Old 04-28-2004, 11:24 PM   #18
Default Re: servos
I have some real strong servos 111.oz torque on 6 volts or 103.oz on 4.8 bought them from http://www.servohut.com for $15.00 each. They also have the SO6MG metal gear servo which moves any tire for $20.00!
I have not seen better servos for the cost. Take a look at them.
You pull, I push, we win!
Rickshaw_runner is offline   Reply With Quote
Old 04-15-2008, 12:37 AM   #19
hitec
phase10 is offline   Reply With Quote
Old 04-15-2008, 08:13 AM   #20
DaViolentOne's Avatar
Servo saver? On a crawler? Not many use them if any at all...
The only servo saver I'd use would be the cool Junfac one for Clods... Outside of that, no thanks... I'd rather have the full push/pull of the servo instead of having to get an uber high torque one 'cos the saver mushes out so much...
They kinda make it harder to work a rig thru something if they keep mushing out or a bump on a rock can make your wheels go the complete opposite way than you need...
DaViolentOne is offline   Reply With Quote
