| | #1 |
| I wanna be Dave Join Date: Jun 2004 Location: Not where I'd like to live
| So It looks like I've stripped the servo arm screw on my H645MG servo. Can anyone give me any ideas? Oh and an aluminum servo arm too. |
| Sponsored Links | |
| | #2 |
| 06 Super National Champ ![]() Join Date: Jun 2004 Location: Tennessee
| might be able to tap the output shaft for a hair larger screw. OFNA makes aluminum servo horns with plastic inserts to fit most anything. |
| | #3 |
| yup those are the hors I've got. but the screw holding it in is a phillips and rounded out. |
| | #4 |
| Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
| Can you get a new gear set? The screw threads into a gear... |
| | #5 |
| RIP Buster ![]() ![]() ![]() Join Date: Mar 2004 Location: Norcal
| When I strip screws out I take my dremel and grind a flat head slot in it and then use a flat head screw driver to get it out. All you need it a little bit and make sure you put alot of pressure on the screw driver so it does not slip again. I have extra screws if you need one. |
| | #6 |
| Luckily I had the screw out a bit before it rounded out. so I hack a line in it and flat bladed it out. After heating up the screw head with a soldering iron. But I can't find a screw. So I'm reusing it. John can you bring me one? I doubt I'll be able to find one in Morgan Hill tomorrow. So the LHS didn't have aluminum servo horn that didn't use the plastic adapters. But i bought another Ofna horn just for the plastic adapter. I guess I'll order one. Does anyone know if you can get just plastic parts? |
| | #7 |
| Rock Crawler Join Date: Feb 2004 Location: Astoria, Oregon
| I just used a little super glue. |
| Thread Tools | |
| Display Modes | |
