Thread: DX3 Help!
Old 12-31-2008, 05:40 PM   #1
Default DX3 Help!
So i re soldered my toggle switch so that the left and right wires were switched so my controls on the toggle were how i wanted them. When i put the controller back together and turned it on i had a problem. When i turn it on, it makes the usually beeping noise, but the screen is lit up completely. Every line on the screen is black. It does this for a second and then the whole system shuts off. I tryed rewiring the switch back to normal and still it does this. Anyone have any suggestions?
Calicrawler23 is offline   Reply With Quote
Old 12-31-2008, 05:58 PM   #2
I'm pretty sure that it's fried. Is there any way that i can send it back to Horizon?
Old 12-31-2008, 06:24 PM   #3
72Blazer's Avatar
Did you do the mod JUST like this ?http://rccrawler.com/forum/showthread.php?t=54770
Check to make sure you didn't create a solder "bridge" between the runs or solder points.If it is fried I really don't know if Horizon will repair it,just have to ask them.Don't think they will warranty it either.
72Blazer is offline   Reply With Quote
Old 12-31-2008, 06:25 PM   #4
Yea forget it. This thing's fried. Mod please delete.
