Thread: hitec servo specs
Old 01-01-2009, 01:51 PM   #1
Default hitec servo specs
i was just wondering what i'm really getting out of this sevro. it's a hitec hsr 5995 tg. this is on my axial scrpion with novak 55t and speed control. the manufacturer states-stall torque @ 6v 333oz/ @ 7.4v 416oz/standing torque-@ 6v 433/ @ 7.4v 541oz. i'm using a standard 3300mih stick pack for the time being. so what am i really getting here?
brokendiff is offline   Reply With Quote
Old 01-01-2009, 09:50 PM   #2
What is the actual voltage you are applying to the servo?
Playing around with the spec'd figures indicates that the output torque is fairly linear wrt to the applied voltage (based on the 2 defined points).
Or, expressed as a mathematical equation:
Torque = K (constant) x voltage
If that is not close enough for you, you could set-up the servo with a moment arm, with the free end pressing down on a weigh scale to read the force. Take the force value and divide it by the arm length to get a torque figure.
Narly1
Narly1 is offline   Reply With Quote
Old 01-02-2009, 01:31 PM   #3
7.2volts
Old 01-02-2009, 01:34 PM   #4
actually, MOST RX units only pass 6v thru them. so even on a 7.2 or 8.4v 8cell, the rx will only allow 6v to pass thru (most of them, not all).
also most servos wont handle over 6vs. unless otherwise stated as the 5955s are. so unless your running a power splitter for the steering servo power, your servo is seeing 6v and getting 333 in/oz of torque.
Timmahh is offline   Reply With Quote
Old 01-02-2009, 08:14 PM   #5
alright,thanks. i was hoping for a bigger number but its still pushing rocks.
Old 02-12-2009, 10:15 AM   #6
Good to know. what speed controls allow more? my trxxass vl5 allow more...why wouldn't they all? jumping in midstream, sorry.
minor_threat is offline   Reply With Quote
Old 02-12-2009, 10:23 AM   #7
DIRTY SOUTH
Badd's Avatar
get yourself a Castel BEC that away you can adjust the Voltage .
Badd is offline   Reply With Quote
Old 02-12-2009, 10:24 AM   #8
What esc are you using? most esc bec's only push 5v. I know fxr's are 6v. If you got a bec you can set it to w/e you want, you would even notice a big difference with a bec set at 5v b/c it handles a much higher load, I think it's 10a.
Edit: Badd beat me to the post.
D-ran83 is offline   Reply With Quote
