Thread: radio questions
Old 01-02-2009, 12:12 AM   #1
Default radio questions
i have an old duratrax 3 channel radio made by futaba that is 27mhz and was wondering if i can use that for my ax10 and my nitro? but not at the same time?
i would put in a matching crystal into the reciever on the ax10 that matches the transmitter so i would not have to do any crystal swapping to run trucks.
will this work?
sorry i am cheap and hate spending money when i have something that can to the job.
some more info on the tx is that its a pistol grip with a trigger,steering wheel with steering trim, and reversable servo switches for the trigger and has a flip toggle that activate the fwd/rev on the nitro.
i have no planes for setting up dig on the ax10.
will this work?
quarterpounder is offline   Reply With Quote
Old 01-02-2009, 10:28 AM   #2
Should work OK. You may have to change servo direction each time you change model if you don't have multiple model capability on that radio.
One-eyed Jack is offline   Reply With Quote
Old 01-02-2009, 02:06 PM   #3
oh well reversing servo is simple as flippin a switch, thanks
