| | #1 |
| Newbie Join Date: Jul 2008 Location: tomsriver N.J.
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jun 2008 Location: Mudville
| you ll need to go into your desktop software, and make some changes to chn 3 or 4 (depending on what chnl your usind for dig). you need to change the steps to 3 on that channel, and then tell it to be in trim mode. then once you have it set to move in 3 steps, you ll have to adjust your epa on the channel your using. if you have any further ?s feel free to PM me your phone number, and i can give you a call and walk you thuru it, as long as your in the states. |
| | #3 |
| RCC Addict Join Date: Jul 2008 Location: Sin City
| First set channel 3 as shown to trim. ![]() Then under Soft Keys pick the key you want to use. The 2 way by the wheel is the easiest to use. ![]() This setup will start the servo in the middle. The switch will move the servo in one direction or the other as directed in 3 steps. This is the setup i use on my MoA switch dig but its the same thing on a normal dig. Set your end points to ZERO the move them out as needed. NOT the other way around. You will burn up the servo. Enjoy |
| | #4 |
| Thread Tools | |
| Display Modes | |
