Thread: good brushless motor
Old 01-04-2009, 05:28 PM   #1
Default good brushless motor
im looking to get a good brushless motor with alot of tourqe.I dont know anything about rebuilding brushed motors. i have 3s lipo and mamba max esc.ive seen alot of holmes hobbies motors on here ive been leaning towards,but witch one with tourqe and a lil speed or whats another good one.....thanks
mike267 is offline   Reply With Quote
Old 01-04-2009, 05:41 PM   #2
What's In The Box!!!!!!!
Lil Jon's Avatar
Any of the crawlmaster's should be fine.
Lil Jon is offline   Reply With Quote
Old 01-04-2009, 06:34 PM   #3
pm holmes he will give u the 411.
thevulgarcowboy is offline   Reply With Quote
Old 01-11-2009, 05:53 AM   #4
Hi
One bit of advice is to look at the front of the motor and see if it is flat. I have a motor which is not, and the fit to my Axial AX10 Scorpion motor plate is less than perfect due to this.
Migs
Migs is offline   Reply With Quote
Old 01-11-2009, 08:45 AM   #5
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
The crawlmasters have a lot of torque. The revolvers have almost the same, but they are easier to gear because they are smaller. Otherwise you will have to pick up a Novak or Tekin sensored system to get brushless that crawls well.
JohnRobHolmes is offline   Reply With Quote
Old 01-17-2009, 07:06 AM   #6
thanks for the reply as for the crawlmmaster 850 or 1000,are these hard to gear right if so what gearing do you sugest with them....thanks
Old 01-17-2009, 12:03 PM   #7
i run a turnigy outrunner brushless motor that works awesome everytime. its small and has tons of power. it seems like a good brushless motor. i have about 6 or 7 buddies that run the same one to.
webster420 is offline   Reply With Quote
Old 01-17-2009, 04:08 PM   #8
pnm
What kv in Turnigy?? I run 1000 kv Holmes Crawlermasters with 3s lipo but don"t get the wheelspin i wanted... ( R2 HD gearbox) ... tons of torque
pnm is offline   Reply With Quote
Old 01-17-2009, 04:16 PM   #9
i run the turnigy 860kv with a 3 cell lipo. it has plenty of wheel speed for me. i ran a 2 cell on it for a little while but the 3 cell helped it a ton
Old 01-17-2009, 04:51 PM   #10
pnm
Ok! Looking more wheelspeed than 35 t lathe... love the low end but need more top (like brushed Graupner speed 600 ).
Old 01-17-2009, 10:39 PM   #11
i am looking for same thing, only plan on trail riding and little bit of crawling, but want 15-20 mph.
clay7160 is offline   Reply With Quote
Old 01-17-2009, 11:09 PM   #12
Dream...Think...Create.
Nova's Ark's Avatar
Crawl Masters are great motors and all about torque. If you are after wheel speed, you need to answer a few questions. The Mamba Max is great and so is the 3S lipo. I would suggest a CC BEC just to keep the ESC cooler.
As for KV, 1000 is the lowest I would go, but I would really be looking for a 1250KV out runner and maybe even a little bigger.
What size rim and tire are you going to run? 1.9 or 2.2? The final height of the tire will play into wheel speed as well.
What transmission? Any R2 is tricky to gear for wheel speed. You would need a 22 tooth pinion to really get any good wheel speed. The higher you go in the gearing, the less smooth the start up power will be on the low end for crawling. An Axial transmission with 87spur and 22pinion is pretty good, but it's not super fast. I have that in a 1.9 scale rig with a Holmes 1000KV Crawl Master Sport. I wish it was faster. I am using a MM, CC BEC, and 3S lipo.
I have a BM9 in a R2 in a custom 1.9 Hilux with a MM, CC BEC, and 3S lipo and the pinion is a 18 tooth. It's not "fast" either. It does slow speed crawl better than the other 1.9 but it's not as fast either.
I love brushless outrunners for the strong drag brake and ease of maintenance, but they are definitely not for everybody. If you can get it tuned properly though, they are amazing. I am using Holmes 1000KV Crawl Masters in both mine and my sons 2.2 comp rigs. They are Axial transmissions that are geared with 96 tooth spurs and 18 tooth pinions. They are super smooth to run, especially for brushless. 3S lipos, MM's, and CC BEC's. Good luck in whatever you decide.
Nova's Ark is offline   Reply With Quote
Old 01-17-2009, 11:17 PM   #13
Nova's Ark's Avatar
If you two are both looking for that kind of wheel speed, you need either Holmes Puller motors (which are brushed) or a quality 27 turn brushed motor. I suppose you could try a Holmes Hand wound 35 turn and volt way up for the desired wheel speed. I would also suggest an Axial transmission. You have more gearing options than a R2. 3S lipo would be OK but 4S lipo would be better. The puller is an awesome motor. Great slow speed control with instant wheel speed.
Old 01-18-2009, 09:45 AM   #14
what kind of wheel speed are you getting with your set up with the 1000kv motor and gear set up
Old 01-18-2009, 02:29 PM   #15
I went with a MM 5700kv and a 9T pinion. Very good speed and good trail motor...hindsite, I would of gone with the 4600kv..and the same 9t pinion.
squatch71 is offline   Reply With Quote
Old 01-18-2009, 08:49 PM   #16
I am all grins when I run my Mtroniks sensorless 600 size brushless.
It has torque, I added a few extra capacitors to the ESC and have not noticed any cogging, but it might have too much RPM.
That of course makes it way too much fun.
justadork is offline   Reply With Quote
