Thread: truck shuts down
Old 01-26-2009, 08:30 PM   #1
rocksrock's Avatar
Default truck shuts down
Have a prob with my truck shutting down when I turn. It all started when I put in a JR ds8711. The electronic's are cc BEC,fxr, spectrum rec,and split 8 pack battery
rocksrock is offline   Reply With Quote
Old 01-26-2009, 09:14 PM   #2
Keep it real
Tanis's Avatar
Do you have the red wire pulled on the FXR? The CCBEC shouldn't be shutting down with just one 8711.
Tanis is offline   Reply With Quote
Old 01-26-2009, 09:41 PM   #3
Looking for scale goodies
Racer4Life's Avatar
I had to run a splitter. Run the BEC and servo into the splitter then into the servo plug for the reciever. Fixed my issue.
Racer4Life is offline   Reply With Quote
Old 01-26-2009, 10:04 PM   #4
rocksrock's Avatar
Yes the red wire is pulled out. And ill go to the LHS tomorrow and get a splitter and give it a try. But Do you still have to leave the red wire out? Thank's
Old 01-27-2009, 12:26 PM   #5
Racer4Life's Avatar
Yes
Old 01-27-2009, 12:43 PM   #6
take the white wire out of the BEC and red out of FXR
twistedone is online now   Reply With Quote
Old 01-27-2009, 12:57 PM   #7
......../-__-\........
helhedded's Avatar
this will help, I use it on my rig.
helhedded is offline   Reply With Quote
Old 01-27-2009, 02:27 PM   #8
rocksrock's Avatar
Ok. Tried the splitter still shuts down. Ill try the voltage protector now.
Old 01-27-2009, 02:54 PM   #9
helhedded's Avatar
also if that doesn't work you need to isolate your servo power, like this
Old 01-27-2009, 06:54 PM   #10
rocksrock's Avatar
Just put the voltage protector on and it worked. I Y'd it in with the BEC. Thanks guys for your help
Old 01-28-2009, 01:27 AM   #11
i used to run this set up with my fxr and the thing would constantly die. had to isolate the cc bec to the rx and it did better but as soon as i dont have a fully charged pack it starts cutting out.
93'wrangler is offline   Reply With Quote
