Thread: 3 position switch on spektrums
Old 01-28-2009, 10:34 AM   #1
Default 3 position switch on spektrums
I want to put dig on my AX10 scorpion and was wondering which 3 channel spektrum radio would have a 3 position switch. Any help is appreciated. Thank you.
Rumhead is offline   Reply With Quote
Old 01-28-2009, 10:50 AM   #2
1/6 Willys Extreme Scaler
reddevildemo's Avatar
DX3R
reddevildemo is offline   Reply With Quote
Old 01-28-2009, 12:27 PM   #3
DX3 or DX3R
Foxracin is offline   Reply With Quote
Old 01-28-2009, 01:21 PM   #4
TN State Champ 2011
Pdog7's Avatar
DX3R
Pdog7 is offline   Reply With Quote
Old 01-28-2009, 01:32 PM   #5
Does the dx3s have the 3 position switch or just the R?
Old 01-28-2009, 01:52 PM   #6
Crap,
So, I bought the DX3.0 for nothing? I am installing a 2 speed tranny on my rig, will this radio not work? I have a winch I wanna run too, but, I can do that manually. Thanks for any help.
SMFtwstdHICK is offline   Reply With Quote
Old 01-28-2009, 02:21 PM   #7
morg59jeep's Avatar
I am wondering the same thing. Can the 3.0 be used for 3 positions? Like for the new losi 1/10 dig?
morg59jeep is offline   Reply With Quote
Old 01-28-2009, 02:22 PM   #8
The 3.0 has a 2 positiuon 3rd channel so I should work fine for a 2 speed transmission.
Old 01-28-2009, 02:23 PM   #9
No it only has a 2 position 3rd channel.
Old 01-28-2009, 02:47 PM   #10
morg59jeep's Avatar
dang... I could get this radio for $150 with reciever and 2 servos... I will have to keep looking
Old 01-28-2009, 02:49 PM   #11
does the dx6i have a 3 position switch or a channel to use the dig completely. i am about to buy one.
greasemonkey85 is offline   Reply With Quote
Old 01-28-2009, 02:50 PM   #12
if you want the option of more channels(for future use)... look at the Dx6i... they are around 179...
EDIT::i saw greasemonkey's post... the Dx6i does not have 3 pos switches... but you could use the extra channel on one the sticks for your dig( mechanical type) or if you run an electro-dig... you can program it in...
PEDEcrawlerguy is offline   Reply With Quote
Old 01-28-2009, 02:57 PM   #13
DX3S third channel is 2 position only :-(
j33pownr is offline   Reply With Quote
Old 01-28-2009, 03:01 PM   #14
Meaning, I am screwed? Grrrrr...
Old 01-28-2009, 03:08 PM   #15
Whats electro-dig
d-fly is offline   Reply With Quote
Old 01-28-2009, 03:14 PM   #16
on a MOA rig... using a servo to control a switch that cuts power to an axle...
Old 01-28-2009, 05:19 PM   #17
Well, found my answer for the 2 speed tranny I want to run. I can use the third channel for it. I just have to adjust the end points and make sure the settings are zero before I install the servo.
Hope everyone's issue gets resolved.
Old 01-28-2009, 08:51 PM   #18
i am trying to figure out what i would use, for that. hmmm......
Old 01-28-2009, 08:54 PM   #19
DX3R is the way to go IMO, super easy to adjust and all the features i can ask for.
Ryan33 is offline   Reply With Quote
Old 01-28-2009, 08:59 PM   #20
Need Tough Links?? PM Me
xirtic's Avatar
DX6 or DX6i....MIX channels to get 3 positions for the dig controlled by ch 5 and 6. This is how I do 3 position dig on my shafty. Will also use mixing for the TX dig on my Bully. I am a HUGE stick radio fan for crawling...lots of flexibility. Throttle return on the DX6i will require sending in the radio to HORIZON to do the mod unless you can source the parts. The DX6 can be modded at home...EASY.
xirtic is offline   Reply With Quote
