Thread: spektrum power cap
Old 02-17-2009, 09:32 PM   #1
Default spektrum power cap
if i were to use the spektrum power cap on my 3 channel rx while using steering, dig, and esc with a ccbec where would i plug it in?
m3kan1k is offline   Reply With Quote
Old 02-17-2009, 11:17 PM   #2
depends on how your cc bec is hooked up. my bec is only running steering, i had some extra male and female battery plugs. i used these to make a y style plug, with red and black wires going from bec to my servo, and the white or yellow wire getting the signal from the rx to the servo. everything plugs in nice and easy. while i get to keep my cap plugged in to the BIND/RS port on the rx. hope this helps. i just set mine up yesterday
RobCam is offline   Reply With Quote
