02-18-2009, 11:37 AM | #1 |
Newbie Join Date: Jul 2008 Location: chandler AZ
| looking for some good wheel speed help...
currently i have a novak 55, rooster crawler esc. stock axial pinion and spur. and using 8 cell 1500mah split pack on front axles. after using it for quite a while i have some wheel speed issues. i was never really fast in the first place. i was wondering if i should go down some turns on the motor,or just go lipo? mess with gear ratio? im not really into going brushless. was wondering what are some good setups, for good torque and wheel speed. any advice is appreciated |
02-18-2009, 11:44 AM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Suburbs
I would say go down to a 45t or 35t motor...im running a 55t and 18t pinion and it isn't quite fast enough...going brushless tho
02-18-2009, 12:04 PM | #3 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
what pinion/ spur combo are you currently running?
02-18-2009, 12:06 PM | #4 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
Go with a 3cell lipo 11.1V. This will give you an appreciable difference in wheel speed and torque. |
02-18-2009, 12:57 PM | #5 |
If you are running a 12/87 gear setup change that first. A 15/87 would be much better. If that is still not enough wheelspeed then go to a 35T Torquemaster from Holmes Hobbies with the 15/87 gearing. I ran the 35T on 11.1V with 15/84 gearing on my GC2 and it had all the wheelspeed I ever wanted, almost too much. With you 8 cell pack it should be a nice setup. |
02-18-2009, 09:48 PM | #6 |
im guessing 12/86 is axial "stock" so thats what im running. 15/87 with a 45 sounds good. you say it has almost "too much" so a step down. i figure cuz i want a good amount of torque w/ wheel speed. thanks much!!! |
02-18-2009, 09:54 PM | #7 | |
I wanna be Dave Join Date: Oct 2006 Location: Centered
A 45T should put you in the ballpark with an 8 cell, and then you can tweak with pinions...they're cheap ;) | |
02-18-2009, 10:01 PM | #8 | |
CreepyCrawl says stock is 14/87 (I've never bought an Axial kit, only the axles and tranny) so the gearing is prolly pretty good. If you want to spend less money you could try an 18 tooth pinion but that wont get you much more. | |
02-18-2009, 11:58 PM | #9 |
RCC Addict Join Date: Nov 2007 Location: BV
3 Cell Lipo is the hot ticket for wheelspeed, but you don't want to go to 3 cell with the speed control you have, you'll burn it up. Try a 45 or even 35 turn motor, and if you're still not happy go get a speedo that can handle the volts (I like the Mamba Max and the Tekin FX-R. The sidewinder is also apparently good, I've just never had one. Also, Holmes Hobbies is eventually coming out with a good speedo with a good switching BEC built-in. It looks like Castle is gonna make it, so it will probably be worth the wait) and a 3 cell. As a side note, I was really never happy with the 45 and 35 turn integy lathes. They just don't have much torque. The handwounds (brood, HH, JP's etc... but not Integy. Their handwounds are not very good IMO) seem to have way more torque and low speed control. Well worth the extra if you ask me. I had one of the early 35T warriors in my old shafty and it was awesome. Second only to the cobalt puller that replaced it Last edited by chrisjlittle; 02-19-2009 at 12:02 AM. |
02-19-2009, 12:08 AM | #10 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
I would start by stepping up to a 16t pinion. Then if you still want more wheel speed get a 45t or 35t motor. I am running 16t/87t gearing with a HHH 35t and 3s lipo and it flat halls the mail. I am about to step up to my 7t puller and gear the tranny down to a 12t/88t combo and going with the hi gearing bevels in the front axle. Thats another option for you as well. Get a set of the option hi gear bevels for the front axle and that combined with a 16t pinion will make a big improvement on wheel speed as well as help reduce toque twist and also help on steep climbs. So all that being said I would get a 16t pinion and also a set of the optional hi gear bevels for the front axles. |
02-19-2009, 02:46 PM | #11 |
Quarry Creeper Join Date: Apr 2008 Location: Carson City
Everyone says get a holmes hobby motor but how they are always out of stock?
02-19-2009, 03:03 PM | #12 |
Castle Creations Sidewinder 11.1 3s 1250mah Lipo (1-hour run-time) 45t motor stock gearing ... will make you a very happy man. 8-) |
02-19-2009, 03:06 PM | #13 |
Rock Stacker Join Date: Jan 2006 Location: Willamette Valley
10 cells and a 35t is Great!
02-19-2009, 09:44 PM | #14 |
ill be getting lipo for sure. would you say that the sidewinder the way to go or could i get away with a mamba micro pro(just for size) is the PC setup kit worth the money? ill more than likely get a 45T w/ a 11.1 3c lipo. and play around with pinions.i want good wheel speed but not too much( got alot of high grip rock out here in AZ) hows that sound? any more ideas are welcome...
02-20-2009, 07:49 AM | #15 |
the pc set-up is worth the money. just make sure you get a castle link for the sidewinder.
02-20-2009, 09:11 AM | #16 |
Pebble Pounder Join Date: Jan 2008 Location: E. Concord
3 cell lipo or a 35t or 45t will do you good
02-20-2009, 12:50 PM | #17 |
Quarry Creeper Join Date: Jun 2008 Location: Phoenix
I have the sidewinder and a cc bec the castle link is well worth the money. You can program just about every thing for it and you don't have to read some stupid manual and follow beeps. The castle link is also way cheaper than the tekin hotlink
02-20-2009, 01:26 PM | #18 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
I'm with the 35T and 11.1 Lipo is almost to much....ALMOST. I have a 35T and 7Cell and its just right for me, your 8C might be the ticket, running 16 T pinion and stock spur in my Axial scaler. I put my 5700kv and Mamba with my 11.1 Lipo.....that's to much. Kinda cool dukes of hazard tire screaching on the cement though!!!!! |
02-20-2009, 10:22 PM | #19 |
Pebble Pounder Join Date: Dec 2008 Location: west carrollton
11.1v and 45t
02-21-2009, 07:58 AM | #20 |
Pebble Pounder Join Date: Dec 2007 Location: CA
I have question : if you use 11.1 v. lipo, do you need external bec for your Servo ?
