| | #1 |
| Rock Stacker Join Date: Feb 2004 Location: kelowna b.c canda
| okay I have a 645mg kicking around and i would like to turn it into a winch how would i go about doing this?? anyone know how to |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Jul 2004 Location: The other Crawler State
| | #3 |
| RIP Buster ![]() ![]() ![]() Join Date: Mar 2004 Location: Norcal
| I don't think there is enough throw in a standard steering servo. Maybe with some type of reduction attached. |
| | #4 |
| I thought to use a little motor on some kind of a reduction and a spool off of that. To operate it, use a mini servo on an mechanicall speed control to reverse the motor for reeling out and the throw it in forward to reel in. I know old school, but them speed controlers is all we had at one time. |
| | #5 |
| Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| If you look inside the servo, there should be a round brass peice in there somewhere. I should have a nub sticking up inside that prevents the servo from turning a full 360*. Just shave that down with a dremel and reassemble. I did it to a Traxxas 2018, but that was a long time ago. |
| | #6 |
| Quarry Creeper Join Date: Sep 2004 Location: Michigan
| you have to remove the physical stops and if I remember right I had to also make it not turn the pot. Find a junk standard servo to play with first before you wreck your 645. |
| | #7 |
| I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
| Here you go: http://www.acroname.com/robotics/inf...y/assm1_2.html That's a write up for antweight robots, but it works. I've modified 6 or 7 servos for full rotation back when my school's tech. club did the battlebots thing. Very simple to do. |
| | #8 |
| The Wheels Keep Turning ![]() Join Date: Jan 2004 Location: Phoenix, Arizona
| i did this to a servo, removed the stops inside and also removed the coupling between the ouput gear and the potentiometer. it will spin in either direction forever until you bring the tx position back to neutral. |
| | #9 |
| Rock Stacker Join Date: Jun 2004
| go to a top shop and buy those cranes pull it apart and make up some thing with all the gears etc and it comes with the little halder for the cord with a gear on the side |
| | #10 |
| Rock Stacker Join Date: Apr 2005 Location: Des Plaines
| i stuck my servo in a box a put along tamiya screw through it with the screw going into the servo head and there you btw i did the usual wire the main motor and trimed the servo gear |
| | #11 |
| That Was Totally Ninja! ![]() Join Date: Mar 2004 Location: Whore Island
| For more information on making servos into winches, try the search function. The topic has been covered a few times. Have fun! Ryan |
| | #12 |
| Rock Stacker Join Date: Aug 2005 Location: In The Sticks right next to the STONES
| my son and i have 3 of those xtreme rock machines and we have stalled the trannys out on all but 1 of them.(before the belts wore out) i dont think that they would be strong enough to support the weight of a large crawler. we also put a 4 cell pack for the rx on one and almost burnt the motor up in less than 2 mins. if you can figure out a way to make it work i will most definately sacrifice one for my txt 1. good luck! |
| | #13 |
| RCC Addict Join Date: May 2005 Location: Roy/Eatonville, WA
| I just modded a Traxxas 2055 for continuous rotation, Its fairly simple and if I'd have known exactly what I was doing it would have taken me a couple minutes less, but still only took 5 min using only side cutters, the file on a swiss army knife, a regular hand file and a #0 philips screw driver. The first thing is to open the case up, but you knew that already, then pull the gears off(remembering where they go of course) you'll be left with the end of the potentiometer sticking out of the case, cut/file this down till it no longer engages the out-put gear. Heres a picture of a modded one with a normal one in the fore ground. (yes I know my pictures suck, but I'm tired and didn't spend much time on them) On my servo there was also a stop on the output gear, my gears are plastic so i just sliced it off with a hobby knife, on an MG if there is one youd just have to file it off. Heres the modded(gray) output gear with a normal(white) one. I put black marker on the tab so they would be easier to see. And heres a crappy low quality vid (I was standing directly under a light and it was that dark, my cam really only likes natural light, and its midnight here. Click here to watch mod-vid Last edited by Trike Kid; 08-17-2005 at 01:55 AM. |
| | #14 | |
| Pebble Pounder Join Date: Jul 2004 Location: SOJO
there is no way that the tranny would work for a winch.. me and my buddy have about 10 of these wally-crawlers, and all have stripped the gears inside.. they are sh!t | |
| | #15 |
| how are you guys managing to strip them, I have had two and went through all my belts. The inside of the tranny looks like new. |
| | #16 |
| Pebble Pounder Join Date: Jun 2005 Location: Millerton, PA
| what i wanna know is how are you gettin the wheel nuts off and the axles out? |
| | #17 |
| They include a wrench, you take one wheel off and yank the axel out with the other one. Needle nose pliars would work to take the nut off as well. |
| | #18 |
| Huh. Mine never came with a wrench! BA$TARDS! |
| | #19 |
| you must have an older one, just use a set of pliars |
| | #20 |
| Newbie Join Date: Jan 2004
| if you have the mechanical stop on the output gear/ shaft you have to cut that off. also on the back of the gear there's a little bit of plastic where the potentiometer goes into, you have to take that out and center the pot (with everything powered up and the stick and trim in neutral then put the servo back together and you're done bdr |
| Thread Tools | |
| Display Modes | |
