04-11-2009, 10:37 PM | #1 |
Newbie Join Date: May 2008 Location: Scottdale
| Duratrax 8T esc
I wanna run rear steer on one of my crawlers and have a duratrax intellispeed esc capable of handling an 8 turn motor. Anyone know if this setup will work without overloading the esc. The duratrax does have an internal bec of 5 amps/ 1volt. Thanks.
04-12-2009, 05:19 AM | #2 |
Quarry Creeper Join Date: Nov 2007 Location: NH
rumhead, I think you have that backwards, the bec on that esc is probably 1 amp at 5 volts. If that is the rating of the bec then it won't be enough to run two servo's.
04-12-2009, 07:17 AM | #3 |
Sorry bout that I had it backwards. Thanks for the help. I'll have to get a different esc.
04-12-2009, 11:37 AM | #4 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
If your going to be running two servo's you should be running a standalone bec |
04-12-2009, 12:06 PM | #5 |
Newbie Join Date: Feb 2009 Location: Norcal, Davis
Or run a receiver battery pack to power the sevros. =)
04-12-2009, 12:19 PM | #6 |
Rock Stacker Join Date: Aug 2006 Location: webster
The castle creations bec is a heck of alot cheaper then a whole esc and it will allow you to boost the voltage available to your servo to use giving it higher power and faster transit speed
