![]() | #1 |
Rock Stacker Join Date: Mar 2009 Location: uk
hi guys! i just got my MRC a fes days ago and im thinking of upgrading. id been reading about which electronics upgrade to go and i ended up going for this.... https://www.tcscrawlers.com/Tekin-FX...6-p-17307.html but b4 ill get this i want to make sure that all etronics that ill be getting will be compatible with each other or at least with the motor and esc. for the sevo i like this hitec: http://www.hitecrcd.com/servos/show?name=HS-645MG but with the bec and batteries i dont know what to get. what i mean is im not sure about the voltages and whether its compatible with the items above. a little advice will help. one more thing, can i still use the stock tx and rx with the upgrade. im thinking og getting the tx and rx last. just a tight budget. ![]() thanks a lot! more power to all! |
![]() | #2 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
That esc will work, but that motor wont unless your running an axial/rc4wd tranny in your mrc for a 540 motor. That servo works great, I run one on my mrc also. Either a tekin FXR or tekin b1R and a HH mini torquemaster. CC bec works FXR http://holmeshobbies.com/product.php...0&cat=2&page=1 B1R http://holmeshobbies.com/product.php...1&cat=2&page=1 HH torquemaster mini http://holmeshobbies.com/product.php...&cat=17&page=1 Last edited by Failedabortion; 04-18-2009 at 01:01 PM. |
![]() | #3 | |
| ![]() Quote:
thanks for ur help! ![]() im considering the HH mini torquemaster and the b1r. its a good chance ill go for these 2. provided its in stock. ![]() now the question is battery. ill go lipo's but how do you pick ur battery? i mean do u look at just the volts or something? and what bec is compatible for these? do i need bec in the first place? | |
![]() | #4 |
With the b1R I would run a bec, could probably get away without one if you use the fxr. The Castle creations bec should work fine with it. My personal setup in my mrc is a sidewinder micro, cc bec with a 645mg servo. For lipo's it depends on where you want to mount it, The 600mah losi pack looks really tempting except the price tag... |
![]() | #5 |
how would u know what battery to get that would not burnt out ur lets say esc,servo...? do look at just the voltage? tnx? |
