04-23-2009, 03:12 PM | #21 |
Pebble Pounder Join Date: Jul 2007 Location: Roy
04-23-2009, 03:37 PM | #22 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
PM sent.
04-23-2009, 03:38 PM | #23 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Will place my order next week. Cant wait to try these out to see what they can handle. |
04-23-2009, 07:03 PM | #24 |
| UPDATE: I have a local crawler testing one of these units. His opinion, which a couple people have brought up, is that they want the Unit to Short the motor that it has disconnected instead of leaving it open. The unit may look a little different to accommodate the new wire plugs since it will need to have both motor leads. Anyone else have any opinion on how they would like it? Any other ideas or feedback? |
04-23-2009, 07:13 PM | #25 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
Shorting the motor is good. That's what 90% of us are doing now with the switches. Even with mine shorted I can still get the wheels to turn when I crank up the wheel speed. There was a similar unit that someone posted up in the berg section that could short the motors but it was huge. |
04-23-2009, 07:51 PM | #26 | |
Rock Crawler Join Date: Nov 2005 Location: Livermore
Even with the motor shorted it still can freewheel a little when there is a lot of traction on the tires while digging. Last edited by 51504rock; 04-23-2009 at 07:53 PM. | |
04-23-2009, 07:57 PM | #27 |
no talent hack Join Date: Feb 2007 Location: Redwood City
instead of shorting it maybe you can get it to put a slight reverse load on the motor. i have been doing that with my 4pk and it has been amazing
04-23-2009, 08:47 PM | #28 | |
Say hello to my dactylion Join Date: Jun 2004 Location: On the Boat to Whore Island
Great work Robin. I knew you were the guy for the job... I'm excited to get one in my rig. | |
04-23-2009, 08:58 PM | #29 |
Newbie Join Date: Dec 2008 Location: spain
| could your computer help me?
I need to control two motors? I need two ESC? or can your computer do the trick? Eduardo |
04-24-2009, 12:01 AM | #30 | |
Rock Crawler Join Date: Mar 2008 Location: Arizona
I do not care how it is done, but if you could make it so the the DIG motor locks up evermore so than it does with the 3 pole switches that we use now, you would have a huge hit with the MOA crowd. Like I said in my first post you stuff works really well if you find a way to really lockup the motor this would be a home run. | |
04-24-2009, 05:41 AM | #31 |
Quarry Creeper Join Date: Feb 2008 Location: EAST TN WHERE SHINE IS FREE
I would take 2 if you can get them to short out the motors Looks like a great idea no more guess work on a dig set up |
04-24-2009, 06:02 AM | #32 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
I am not trying to be difficult, but how is the $45-$50 unit per axle different/better/improved over the Dimension Engineering Battleswitch (Robot Switch) that a bunch of people are using with success at the $25 per switch price point that shorts the motors in the same fashion as the Rat Shack Dig solution, but has the higher Amp rating? http://www.dimensionengineering.com/BattleSwitch.htm I LOVE this idea, but I just want to know what the extra cost may be buying me. |
04-24-2009, 06:31 AM | #33 | |
BTW, if you don't want the shorting you can simply not connect or remove the second row of connectors. Then you have the 1.5x1.0 board again. I also added onboard voltage spike protectors to stop most the damage that may be done to the relay contacts. I will have about 12 of these pre-production units in May 1st. If they work well, we will have the production units going on May 8th. | |
04-24-2009, 06:37 AM | #34 | |
Those are rated at 10A and mine are 12A Mine have Contact Arc Supressors Mine are a snap to wire Mine is more compact Mine has a RGB indicator But you have one misconception I just realized!!!!! You only need one of mine, not two. Mine does both motors! So is 2 for $25 or 1 for $58? I think that is worth the $8, but not the $76!!! | |
04-24-2009, 07:00 AM | #35 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Will those of us with pre-orders get the new Shorting version or the one shown? I can't wait. I'm not a fan of the 4 channel idea with 2 ESCs and well tired of complicated mounting of servos and switches! |
04-24-2009, 07:13 AM | #36 |
Rock Crawler Join Date: Nov 2008 Location: SoCal
PRE ORDER PLACED. Last edited by MDcrawler72; 04-24-2009 at 08:06 AM. |
04-24-2009, 08:32 AM | #37 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
I got to see it along with Pinch at the UTRCRC comp and was very impressed. I was a little skeptical without the system shorting the motors but now that it will short the motors I'm sold! Thanks for making these! My dig-a-ma-jig got bumped around last comp and cost me a gate These should take care of that. Less crazy wiring also which makes for a cleaner rig. |
04-24-2009, 08:34 AM | #38 | |
04-24-2009, 08:57 AM | #39 |
support@rc4wd.com Join Date: Nov 2007 Location: Lancaster, Ohio
Its about time I have been waiting for 2 guys to do this . Glad to see one of you stepped up to the task. This will put an end to the soldering nightmares and overloaded switches for sure! Price is perect as well! |
04-24-2009, 09:05 AM | #40 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
Awesome Subscribed and waiting |
