Thread: Diodes for Holmes 35T
Old 04-27-2009, 09:26 PM   #1
Krawln68's Avatar
Talking Diodes for Holmes 35T
Well i picked up my Holmes Hobbies 35T today. Before i install it, i had a couple of questions. Im running a Spektrum Rx and a Rooster Crawler for now, ami gonna need the diodes on it? Also, im running a DNA dig so i had to reverse the wires for it to spin properly. Should i do that with this motor, or just reverse it on my DX3R?
Krawln68 is offline   Reply With Quote
Old 04-27-2009, 09:33 PM   #2
TEAM MODERATOR
Reflection's Avatar
Never added anything to my hand wounds other than the Leads for the ESC to plug into. Never run them on any of my motors for that matter. As far as I know,switching the direction with the wires or inside the radio does the same thing. Personally,if I need to switch the direction,I always switch them at the motor where they solder on.
Reflection is offline   Reply With Quote
Old 04-27-2009, 09:44 PM   #3
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
You won't use diodes. You would use filter caps, which are already installed.
JohnRobHolmes is offline   Reply With Quote
Old 04-27-2009, 10:53 PM   #4
Krawln68's Avatar
Sorry, wasnt exactly sure what they were called. Thank you sir, im looking forward to installing it tomorrow
Old 04-27-2009, 11:27 PM   #5
what do the diodes do or protect ................bob
bob1961 is online now   Reply With Quote
Old 04-27-2009, 11:52 PM   #6
A diode is like a electrical check valve, it allows current flow in one direction but not the other. If you installed any diodes across the motor terminals you'd short it out in one direction, which would fry a reversable ESC. They're sometimes used with forward only ESC's for racing.
Filter caps (capacitors) filter out electrical noise. When installed correctly on a motor they absorb a lot of the RF noise a motor makes, which reduces glitching. It's not really necessary with modern high quality radios and ESC's. Absolutely a necessity for AM radios though.
chrisjlittle is offline   Reply With Quote
Old 04-28-2009, 12:05 AM   #7
thx so on a crawler there's no need really then................bob
