| | #1 |
| Newbie Join Date: Oct 2008 Location: ben lomond
| I'm trying to bind my new Spektrum receiver and it won’t go into bind mode. I'm putting one into my slash and when I turn on the controller to the slash the green light blinks once and turns off. The Spektrum receiver turns on a solid red l.e.d. According to the directions it should be flashing (and yes I didn't mention that in indeed plug in the bind plug). Anyone know why this could be happening?? |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Oct 2008 Location: In the basement...
| Model numbers of RX and TX might help... |
| | #3 |
| Sorry, I have the DX3R with a SR3100 to a standard Slash controller. |
| | #4 |
| Rock Stacker ![]() Join Date: Apr 2007 Location: Nor Cal
| Do you have the Rx powered up, either through the pack that comes with it or via all wired up in the car? |
| | #5 |
| The Rx is powered up through the controler. Should I use the pack that it comes with?? |
| | #6 |
| Doesnt matter, as long as there is power going to it. I usually bind mine by themselves before they are hooked up to anything. |
| | #7 |
| Rock Crawler ![]() Join Date: Apr 2008 Location: SO CAL
| maybe your wire is in backwards |
| | #8 |
| instigator ![]() Join Date: Dec 2008 Location: other side of the track,the bad side
| check your traxxas manual, I gives you special instructions to use a dsm or ism band reciever |
| | #9 |
| That's it my wires are in wrong. Thanks for your help guys |
| Thread Tools | |
| Display Modes | |
