Thread: LiPo setup question
Old 04-30-2009, 12:50 PM   #1
Default LiPo setup question
making sure I am ok to run this set up before doing so:
Novak Rooster crawler ESC w/ 55T single motor
2x -Common Sense RC- 800mAh 7.4v lipo in parallel
im new to LiPo so it would be nice to know that this wont blow up my ESC before i do it... or should i be running these packs alone?
the packs are about 3/4 inch by 3 inch by 3/8 inch thick, dont know if that helps tell what they are... and i think each pack is a 2s pack... can that esc run these 2 packs like that?
MtuCrawler is offline   Reply With Quote
Old 04-30-2009, 01:25 PM   #2
nm figured it out... it bumps me to 1600 mAh and keeps voltage at 7.4v
Old 04-30-2009, 09:25 PM   #3
In parallel yes it will work.
dano104 is offline   Reply With Quote
