| | #1 |
| Quarry Creeper ![]() Join Date: Mar 2006 Location: Howell
| Hey, I'm building my new RX pack for my super, I'll be using a1/4 scale servos and a castle bec. Is 6-2/3A 1500 cells too much for the setup. Am I going to cook something @ 6.0 Volts. Not sure, searched, and never really came up w/ a definate answer. Thanx for your time in advance. |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Oct 2004 Location: Concord
| If it is a stand alone rec. pack you only need 5-2/3a's. 5 of them is 6 volts, 6 of them is 7.2 volts. At 7.2 you could cook some stuff. |
| | #3 |
| Rock Crawler Join Date: Jul 2007 Location: clearfield
| What servos are you going to use? |
| | #4 |
| Tower Pro 9805MG & a 805 Hitec are the servos I'm planning on running. |
| | #5 |
| Rock Stacker Join Date: Apr 2009 Location: San Jose
| The OP says he will be using a Castle BEC. The Castle BEC can easily handle the voltage from 6 cells. In fact I would use 6 cells instead of 5 to give the BEC some headroom to operate. With a switching BEC like the Castle there isn't a big loss in efficiency using a higher voltage pack like there would be with a linear BEC. One thing with the Castle BEC is the default output comes set to 5.1V. You will need a Castle link and PC to change the output to 6V. ~petev |
| | #6 |
| Can anyone else verify his /\ information? |
| | #7 |
| Quarry Creeper ![]() Join Date: Jan 2008 Location: Cyprus
| Why use a BEC if you're going to use a battery pack? |
| Thread Tools | |
| Display Modes | |
