Thread: Have a XP9303 is there people tht PREFER stick radios,,,
Old 05-01-2009, 12:10 AM   #1
Default Have a XP9303 is there people tht PREFER stick radios,,,
I love my JR 9303 for my heli and planks. Is there a set-up that has become preferable to a pistol grip radio that some users prefer sticks to the normal pistol type radio,,,thaks,,,Mike
grouser is offline   Reply With Quote
Old 05-01-2009, 12:25 AM   #2
i have both and i love both(spektrum dx6 and dx2 2.4 radios) i like the dx6 alot and would us that for any comp worthy rig its awsome for scale too, soo many switches and setups
ptbrc1 is offline   Reply With Quote
Old 05-01-2009, 01:40 AM   #3
I just switched to a stick, and I will never go back to a pistol grip. My comp rig gets better controll( a motor on each stick) And my scaler rig, winch is fully proportional!! Since my scaler winch is strong enough to pull my frame in half, this is important
I really Don't know why people always use pistol grip radios? I guess its habbit, or just what everyone is used to.
holycaveman is offline   Reply With Quote
Old 05-01-2009, 05:10 PM   #4
So with my computer radio can I change throttle curves in my radio and make it work like the Castle creations programmable ESC?
Also anyone know where to geet a smaller flexable antenna for a JR XP9303
Old 05-01-2009, 05:32 PM   #5
JSN
Get a DUCK...
http://www.smileyantenna.com/index.php?cPath=43
JSN is offline   Reply With Quote
Old 05-01-2009, 05:33 PM   #6
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I used to be sold on stick radios for full control until I got the Futaba 4pk. It has enough channels for a crawler and enough mixing to do everything. No more bulky stick radio's for me, unless I am flying my planes.
JohnRobHolmes is offline   Reply With Quote
Old 05-01-2009, 06:27 PM   #7
Originally Posted by JSN View Post
ED ZACAREY what I was looking for thanks,,,Mike
Old 05-02-2009, 08:05 PM   #8
What so ya think about this for a setup.
right stick (elavator)/ forward and reverse (stick is spring loaded for getting back to nuetrel)
right stick (aileron)/ front wheel steer
left stick (throttle)/ at full forward=front dig, at full back=rear dig (can you set the radio to do this? the "full forward or reverse thing)
left stick (rudder) rear wheel steer
Old 05-03-2009, 06:52 AM   #9
BigSki's Avatar
I use a DX6i for my scaler and comp rig, I prefer it to the DX3.0 that I was using. I have much better throttle control, a much better range for reverse and I was able to built a gate to control the 3 positions for my homemade dig unit. I rotated the left control 90* so that I had a spring return for throttle and I adjusted the friction for the shifter control.
BigSki is offline   Reply With Quote
Old 05-03-2009, 11:01 AM   #10
I thought about moving or adding a sping to the left side but must keep the radio ready for my helicopter and planes gotta figure out how to make the dig work on the throttle channel ONLY at full throw,,,read read read I guess
Old 05-03-2009, 11:28 AM   #11
I prefer the stick, gives better control imo.
lud98r is offline   Reply With Quote
Old 05-03-2009, 04:27 PM   #12
I have a jr x9303 and I will never go back to my dx3.0. I don 't know why but it seems to crawl a whole lot better. I run my ax10 off of it and soon my berg. I would use a stick radio cause you have so much more control. But my dads 4pk would kick the crap out of my crawler.
HRT5SLCFD is offline   Reply With Quote
Old 05-03-2009, 05:20 PM   #13
I prefer pistal grip radios myself, but with my scaler and dual motor crawlers, I've started using a stick radio. It takes some getting used to, for crawlers, and I fly helis too, but I'll get it once I get some more stick time.
Espeefan is offline   Reply With Quote
Old 05-04-2009, 12:31 AM   #14
So what are your channel assignments?
Old 05-04-2009, 06:39 PM   #15
Well i use throttle (left stick up & down)for my front motor, elevator (right stick up & down)for the rear, and the rudder (left stick left & right)for the front steering servo. I have also use a mixing chanel so i can switch the gear switch and all four wheels move off the throttle stick, and when I move it back I can use the two sticks to control each motor. There are so many diferent digs that the 4pk can't even touch. But the 4pk is an awsome radio too.
