Thread: PunkRC Dig Switch Video
Old 05-01-2009, 06:46 AM   #1
Default PunkRC Dig Switch Video
Big Bear test drove one of my production dig switches yesterday. He was impressed with the product and I was impressed with his driving.
Well I took a video and just uploaded it onto youtube. It can be seen here and here on our store.
http://www.youtube.com/watch?v=0sR6-V1T5ko
http://www.punkrc.com
His use of dig is amazing!!! His use of dig made a impossible line possible. Totally awesome! Thanks!
These units will be shipping tomorrow.
PunkRC is offline   Reply With Quote
Old 05-01-2009, 06:52 AM   #2
TEAM BWD
chad30w's Avatar
Awesome I cant wait to get mine and try it.....
chad30w is offline   Reply With Quote
Old 05-01-2009, 07:25 AM   #3
binaryterror's Avatar
Perfect, glad I got my order in early!
binaryterror is online now   Reply With Quote
Old 05-01-2009, 07:58 AM   #4
Forgive me, but I'm a little slow sometimes. Is this unit using the 3rd ch pulse to energize/de-energize the relay for each motor to start/stop?
ohmyCLOD! is offline   Reply With Quote
Old 05-01-2009, 08:04 AM   #5
The unit is plugged into the third channel. If the channel normally moves a servo (1)Left, (2)Center (3)Right then this will instead (1)Turn off Motor #1, (2)Both Motors On and (3)Turn Motor #2 Off.
Make sence? So instead of moving a servo, you are turning on and off relays.
Most TX's are programmed to control a 3rd channel servo different. In this video, Big Bear uses a button to toggle to "click" the servo/dig switch into different positions.
Old 05-01-2009, 08:06 AM   #6
So theoretically end points dont matter with the dig computer???
nj05nismo is offline   Reply With Quote
Old 05-01-2009, 08:16 AM   #7
Need Tough Links?? PM Me
xirtic's Avatar
Just placed my order for one of these....Looking forward to no more servos for the dig.
xirtic is offline   Reply With Quote
Old 05-01-2009, 08:25 AM   #8
'08 2.2 National Champ
Just Zach's Avatar
Looking great Robin. I can't wait to get mine. Looks like the modifications you made did the trick.
Just Zach is online now   Reply With Quote
Old 05-01-2009, 08:49 AM   #9
Well, each mode has a "range", but for most respects, No it does not matter. You just need to make sure that it actually moves away from center more than a tiny bit (maybe 10°). A 100% throw is great!
Old 05-01-2009, 08:53 AM   #10
Yeah, Big Bear really liked it. It locks them up really good, but still allows for a tiny movement. He said that is what is needed. It was awesome to see him really crawl with it too. I thought "Wow you couldn't have done that without dig"
Old 05-01-2009, 08:57 AM   #11
The vid is sick. It works great need to order mine. Keep up the good work.
Flyin Hawaiian is offline   Reply With Quote
Old 05-01-2009, 09:33 AM   #12
BLADE's Avatar
Looks great Robin dont forget to save me one..............
BLADE is offline   Reply With Quote
Old 05-01-2009, 09:39 AM   #13
Mr Glassman's Avatar
Can't wait to get my grubby hands on mine!
Mr Glassman is offline   Reply With Quote
Old 05-01-2009, 12:21 PM   #14
Giveaway Kang!!!
TEDROCKZ's Avatar
Very good vid... Prepare for the storm.....
Will be ordering some this evening
TEDROCKZ is offline   Reply With Quote
Old 05-01-2009, 01:23 PM   #15
EXW
EXW's Avatar
Default Dig Switch
If I have a 2 position 3rd channel (front dig only) can I set the dig switch to only use "both motors On" and "Turn Motor #2 Off"? Would I do this by setting the radio end points or just not connecting motor #1 to the dig switch?
My preference would be to connect both motors to the dig switch and use the radio endpoints. That way the wiring is cleaner and I don't need to change anything when I get a radio with a 3 position 3rd channel.
Thanks
EXW is offline   Reply With Quote
Old 05-01-2009, 01:32 PM   #16
If you can (maybe also narrow endpoints and) trim off center and make a servo move from a near center position to one side, then you are in luck. I will see if I can just trim my TQ3 to do this.
I'm sure you can get it setup just how you want. If not, I do accept returns.
Old 05-01-2009, 01:46 PM   #17
EXW
EXW's Avatar
Thanks
DX3.0 if that makes any difference.
Old 05-01-2009, 01:55 PM   #18
Team Hardkor Crawlers
kasper's Avatar
Just ordered two switches thanks 05/01/09 when can i expect them thanks for good product
kasper is offline   Reply With Quote
Old 05-01-2009, 03:07 PM   #19
Sweet. Can't wait to try mine out.
I have a feeling these are gonna sell very well for you
BigB_117 is offline   Reply With Quote
Old 05-01-2009, 08:20 PM   #20
Just Zach's Avatar
I have mine in hand and will be testing this weekend. I'll post up how it goes.
