| | #1 |
| Quarry Creeper ![]() Join Date: Mar 2006 Location: Howell
| OK, Now I have a 4 Channel setup Clod Super. I'm changing out my 5645 sevros for a set of Tower Pro 9805mg's. I've read and searched alot on this subject. How do I wire up two Castle BEC's on my 4 channel radio. I have an older Laser 4 and it works great. This is a TCS Stick, with two TR2 ecs,'s and a set of the above mentioned Servos. Can you please help!, Describe how to wire this all up. I'm truly lost on how to wire them up, just link two together? I'm not really up to seeing alot of smoke in trial and error. I can't afford to. $$$ Thanx for your time. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jun 2006 Location: Wisconsin
| Why do you need two? One should do the job just fine, if it's the 10 amp version. No need to make this to complex. Basically all you have to do is wire the BEC input wires to the battery connection on one of the ESCs, and then pull the red wire out of both ESC's receiver plugs. The red wire is typically the wire you need to un-do from the plug. That is the wire of the ESC that supplies voltage to the receiver. Use a really small screwdriver or hobby knife to pry up on the tab of the plug that holds the red wire's connector pin in place, and then carefully pull it out of the plug. Put some heat shrink on the pin to insolate it and then tuck it away somewhere safe. You may want to use it again someday. |
| | #3 |
| Espeefan, Thanx you rule!! Probably the simplest answer I've gotten on this forum, and it makes sense. I'll be Steering in no time now. Supers MUST have 1/4 scale servos. Thanx! |
| Thread Tools | |
| Display Modes | |
