05-02-2009, 02:49 PM | #1 |
Newbie Join Date: Dec 2008 Location: spain
| help configuring a sidewinder
I need to configure manually my new sidewinder to run with a brushed Integy 55T. I go crazy with the beeps and lights and dont get it..... If somebody around here had one...... but I live in Spain and I´m alone. Is there anyway to actually understand the beeps and go to the last menu (the one that switches the SW from brushless to brushed) without having to go though all the tecno music beep party. I go crazy and can keep the count. Thanks Eduardo |
05-02-2009, 02:59 PM | #2 |
Gold Star Baby! Join Date: Feb 2009 Location: Arizona
| sidewinder
hey try this link to see if it helps:http://www.castlecreations.com/products/sidewinder.html at the bottom is a PDF file that is the same instruction manual you get with the ESC |
05-02-2009, 03:41 PM | #3 | |
| I already have that Quote:
The SW starts to make noises and I dont hear those 4 beeps that should start the programming... olus the lights go crazy...... Really complex if somebody that "already knows" does not help. HELP PLEASE Ed | |
05-02-2009, 04:11 PM | #4 |
ok the noise is produced from the motor not the speed control..be sure your esc plug is plugged into the right slot on the receiver . Im not sure what else to help you with but i will try any way i can I have a sidewinder and had my own issues but with help i figured it all out if you continue to have problems the CC support via email works real well they will help any way they can too !! Good Luck |
05-02-2009, 04:49 PM | #5 |
Newbie Join Date: Apr 2009 Location: Chesterfield
I answered this question last week in a thread. I had the exact question. I bought a sidewinder, went through the initial set up and realized it was for brushless and finally realized that I needed to change the programing to brushed. PLEASE read the book that comes with the esc. You also need to place the connected esc in a position where you can see the lights. Don't worry about the beeps. Start on page 20. When it is ready you will the lights beep twice and then pause and beep twice. NExt you will go through all of the programing. Remember one you choose yes it goes onto the next question. My worked after the first time. Please see last weeks post. I just bought a sidewinder yesterday and had the exact same problem. Read the book on how to set it up manually. It is real easy and takes about 10 minutes to run through all of the different setting using forward to answer yes and reverse to answer no on your reciever. Mine worked after the first time through. The last question it will ask you is to switch to brushed with forward and reverse. Once you answer yes you will hear and see the ESC light up and then it is set. I also want to get the computer adapter but with a little patience the manual setting worked great for me today. I will agree I was a little frustrated when I first tried to set it up not knowing the default is for brushless. First impressions are that this esc is awesome. Enjoy!!! |
05-02-2009, 11:55 PM | #6 |
Newbie Join Date: Mar 2008 Location: Auburn
I went through the same process.....nightmarish. The connector was the best $35 I spent...I've changed the configuration many times since.... |
05-03-2009, 05:22 PM | #7 | |
Quarry Creeper Join Date: Dec 2008 Location: Australia
It took me a few goes trying to read it in the manual as I went through the sequences and still didnt get it right so I printed page 22 of the Drivers Ed manual and highlighted the options I wanted. The other thing I did was answer YES to everything until I got to the MOTOR Mode. These couple of things made it a easy job. Once I got it beeping in brushed mode I reprogrammed the options I wanted but with sound this time. | |
05-04-2009, 12:34 PM | #8 | |
| I will do this Quote:
I will try today, thanks eduardo | |
