lost a servo screw........... that holds on the steering/dig alum arm on the servo shaft....who sells just servo screws for that....i'll check LHS..............bob .... |
Different servos use different pitch screws. You should be a little more specific with questions. |
hitec 225/7955...............bob .... |
^^^Yes the 225 uses an m2.6 or at least I snugg fitted one. The 7955 though most probably uses an m3 screw if I remember correctly. |
no,all hitec mini,micro,sub micro,and standard use the m2.6,bob your best bet is to get one from hitec because the screw uses a very specific thread not just a uncommon size:idea: |
cool thx, i didn't know if they sold them by themselves "thumbsup" .............bob .... |
i drilled and tapped a hitec for an m3 screw once in a pinch the night before a comp. its still working well. i dont really recomend it but it can be done. |
I have a 2.5 mm Dubro in my 7955, seemed a touch loose but it has held up through 2 comps now... |
