![]() | #1 |
Rock Crawler Join Date: Feb 2008 Location: UK
Building a Venom with 2 Hitec 7955 steering servos, 2 miniature unbranded diff lock servos and a Novak Goat brushless setup. IIRC, the Goat's BEC is rated at 5A. Will this be enough, or do I need an extra BEC? Seems to work OK on the bench. |
![]() | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
Running all of that I would def add a Castle BEC! Just the 2 regular servos you are running I would run one! Spend the $20 and get one ![]() |
![]() | #3 |
Official Cook of the ECC ![]() Join Date: Dec 2005 Location: Hawthorne, Florida
Yes, you will definately need one.
![]() | #4 |
Newbie Join Date: May 2009 Location: Arvada
I suggest running it without the bec first and then put it on. This way you know exactly what the bec changed and you can learn exactly how it helps. It really makes a big difference for a small fee. Castle all the way!
![]() | #5 |
OK. A couple of things made me ask this question: I fly electric planes. Some of these are fitted with 4 Hitec HS55 servos. They are perfectly happy using the BEC in the cheap ESCs that I use. These BECs are rated at 1.5 to 2A. It's quite possible for 3 of the servos to be in use at the same time (2 for ailerons plus one for elevator). Although the servos are obviously a lot smaller than the 7955, I read an article a while ago that was looking into the relative current draw of a range of servos. Large servos generally don't take more current than small ones. The difference is, steering servos are under a lot more load than aircraft servos (unless you are DS-ing), so the amp draw will be higher. Most BECs are rated at 5 to 7A. My ESC's BEC is rated at 5A. The Castle BEC is rated at 10A, but the default output voltage is 5.1V. To change it to 6V you need to buy a Castlelink - more expense. Finally, my usual suppliers don't stock the Castle BEC, even if they sell other Castle products. |
![]() | #6 | |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
| ![]() Quote:
If you order up your Castle BEC from HolmesHobbies.com he can program it for 6 volts for you before he sends it out. Trust me when I say the $25 CC BEC is worth 3 times that in a crawler. Personally I wouldn't build a crawler without a BEC unless it was something really simple like a 1 servo scaler running on a 2 cell lipo. Last edited by BigB_117; 06-11-2009 at 11:16 AM. | |
![]() | #7 |
Good point about stalling/binding. You've convinced me - I've ordered a Castle BEC. I looked at the link for HolmesHobbies, but, by the time I've paid international shipping and UK customs charges, it'll cost me the same as buying the BEC and the programming kit here in the UK.
![]() | #8 |
You won't be disappointed.
![]() | #9 |
Pebble Pounder ![]() Join Date: Feb 2005 Location: The Aloha State....Aurite!
![]() | #10 |
Suck it up! ![]() Join Date: Mar 2008 Location: Arkansas
There should be a default answer to a "Do I need a BEC" question. If you think you need a BEC, you need a BEC. :-P |
![]() | #11 |
Well, I found a UK supplier who listed the CC BEC on their website. Unfortunately they don't have any stock. Can't find anyone in the UK with stock. Apparently the UK importers have stopped handling Castle products. The new importers (Horizon Hobby?) aren't up to speed yet. |
![]() | #12 |
UK suppliers still have no stock, so I ordered from Holmes Hobbies - thanks JRH. I want to use the CC BEC to power the 2 steering servos, but stick with the Goat's BEC for the Rx and difflock servos. I assume that I need to connect the + and - servo wires to the BEC, and the servo signal wires to the Rx? Will the servos behave themselves with power from the BEC, but no signal from the Rx? I'm wondering if the servos will move unexpectedly after I connect the battery, but before I switch on the ESC. |
![]() | #13 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
Since you are using one main pack, you can run just RX signal from RX to servos with no issue. The red and black coming from the CC BEC will provide power, and the ground will still be a viable reference for proper operation. What I would do is get one Y Harness and one extension. Hack them together so that the CC BEC plugs in and powers the servo side, and only signal goes from RX to servo. It will look like a five legged mess. |
![]() | #14 |
Quarry Creeper Join Date: Mar 2006 Location: SoCal
Novak believes that an external BEC is so important that we include it with our new Goat 3S controller. This is the module that we include: 3-Amp Universal BEC Last edited by NovakTwo; 08-30-2009 at 03:43 PM. |
![]() | #15 |
Excellent. I'll make an adaptor.
![]() | #16 |
Adaptor to run 2x servos from CC BEC: ![]() |
![]() | #17 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Nice job, that sucker is clean. ![]() |
![]() | #18 | |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
| ![]() Quote:
![]() | #19 |
Yes, very nice!
![]() | #20 | |
| ![]() Quote:
I encourage you to contact tech@teamnovak.com with specific application questions. In most 3S applications (regardless of the esc brand,) users find they require the external BEC. | |
