06-18-2009, 01:37 PM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: iderho
| Setting up mamba max help
I hold full throttle on my stock wheely king transmitter, then plug the battery in and the green led flashes while it rings a bit. It says after a few secconds it will go red but it just sits there, green flashing, and no leds after the initial power up one. Any help? Stock WK transmitter traxxas reciever 645mg servo Integy 55t. |
06-18-2009, 02:41 PM | #2 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
I think when it flashes green, that means to give it full throttle. In other words, after it gets into the program setting, let off. When it flashes green, give it full throttle. Been a while since I have ran a mamba though. |
06-18-2009, 02:49 PM | #3 |
But when i give it full throttle it doesnt go to red led like it says it will. I have held it for like up to 15 secconds. Nothing. |
06-18-2009, 02:53 PM | #4 |
Gold Star Baby! Join Date: Feb 2009 Location: Arizona
you might wanna try to see if the throttle needs to be reversed on the transmitter....i just spent two days messin with mine..one thing i did notice that after programming when you turn it back on..unless it sees neutral it wont let it go to run function...well just mt experience so far..to see if it need reversed try to go full rev first and see what it does..i will pm you my number
06-18-2009, 03:02 PM | #5 |
Tried reversing it and not reversing it and doing forward and reverse. No luck. Any other ideas? |
06-18-2009, 03:21 PM | #6 |
sorry man i tried...someone might be able to walk you thru it via LHS on the phone..PMs are not as efficient... i cant think of anything else already said in PMs Good Luck |
06-18-2009, 03:24 PM | #7 |
Alright thanks man Anyone else? What channel is throttle? 1 or 2? I forgot Im tired of testing both every time i think of something new... |
06-18-2009, 03:24 PM | #8 |
Are all your EPA's set to 100% and trims set to 0? Are you letting it go to neutral after it gets into the program mode before you give WOT? |
06-18-2009, 03:32 PM | #9 | |
Will it hurt if the trims are ever so slightly off? Hard to get it dead on.. It doesnt go to the neutral mode. Doesnt program the full throttle. | |
06-18-2009, 03:34 PM | #10 |
Someone with a stock radio will have to help you then.......it could be one of those 70/30 radios.
06-18-2009, 03:40 PM | #11 |
my thoughts too and the same with the 1 or 2 plug on the receiver ..im trying to gogle something but no luck so far
06-18-2009, 03:40 PM | #12 |
Ok. Any other suggestions? EDIT: I try both but it says channel 2 in the manual so im trusting that. |
06-18-2009, 10:30 PM | #13 |
Still cant figure this out, any more suggestions?
06-19-2009, 12:13 AM | #14 |
Bump. Want to get on the rocks |
06-19-2009, 12:30 PM | #15 |
Quarry Creeper Join Date: Feb 2008 Location: port jefferson station
contact castle creations they are more than helpful
06-19-2009, 04:10 PM | #16 |
Went to my LHS today and narrowed it down to the receiver. Now i need a new one :? |
