07-14-2009, 04:39 PM | #1 |
Pebble Pounder Join Date: Apr 2009 Location: Grand Junction
| help sidewinder
my castle creation is hooked up right and everything and it wont controll the motor. it works fine on brushless just not brushed. i have a 55 turn hooked to on 11.1 volts. thanks |
07-14-2009, 04:53 PM | #2 |
Pebble Pounder Join Date: Dec 2005 Location: Texas
You need to reprogram it to run in brushed mode. I think this can be accomplished without the Castle Link, but the Link is the easiest way to gain full adjustability of the sidewinder!
07-14-2009, 04:58 PM | #3 |
it is programed for reversable brushed.
07-14-2009, 05:21 PM | #4 |
Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
running the latest firmware? I forget what firmware it was but at one point you needed to use the red and WHITE wire IRRC to get brushed motors too run... if you have the latest firmware then thats not the problem.
07-14-2009, 05:27 PM | #5 |
im running the latest firmware and in the manual it shows red and black. does the newest frimware make you use red and white.
07-14-2009, 05:51 PM | #6 |
Nope... latest firmware uses red and black... sorry it was not so simple. Are you sure the motor is good? maybe a hung brush keeping it from starting?
07-14-2009, 06:20 PM | #7 |
i touched it to just the battery and it took off. so the motor is good. i think i have a bad esc that wont run brushed motors. because it will run brushless just fine.
07-15-2009, 08:06 AM | #8 | |
(913) 390-6939 Office Hours: Monday - Friday from 9AM to 5PM CST. | |
07-15-2009, 06:01 PM | #9 |
they want me to send it in to them.but i dont have time to do it.
07-16-2009, 03:26 AM | #10 |
Newbie Join Date: Jul 2009 Location: Home
I have a sidewinder that only runs brushed motors, not brushless. I also programmed it right.
07-16-2009, 06:33 AM | #11 |
how much do you want.
