| | #1 |
| Quarry Creeper Join Date: Jun 2009 Location: Earth
| I have just installed 2 FXR's into my Berg and am using a 4PK. I would like to thank Harvey for all his help, but i still have one problem that i can't solve. I have followed Harvey's set up. So i have the front esc on PS1 and the rear esc on PS2. When i connect a battery i have to turn on both esc's using PS1 for the front and 2 PS2 for the rear. All works ok up to now, but here is the strange problem. If i turn both PS1 & 2 off again, PS1 then turns on the rear esc, and PS2 turns on the front. The switches have reversed. But, as soon as they are both back on, PS1 turns off the front again, and PS2 the rear, as they should. Theswitches only reverse when they are both turned off... I have been through Harveys set up a few times and have also performed a factory reset on the 4PK in case i have messed something up, but it is still the same. Has anyone had this problem, or can you offer any help? |
| Sponsored Links | |
| | #2 |
| Pebble Pounder ![]() Join Date: Apr 2009 Location: tumwarter wa.
| 4PK Setups, Tips, Tricks and Help try posting on the above you should get direct help from Harley he keeps close watch on that. |
| | #3 |
| Newbie Join Date: Jun 2009 Location: Mcgregor
| you have to enter after you switch the switches for them to work the way u want goto instruction man. 4pk |
| | #4 |
| Thread Tools | |
| Display Modes | |
