02-09-2012, 10:18 AM | #381 | |
02-10-2012, 10:16 AM | #382 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Futaba 3PM-MX Crawling Radio - Info and setups
Oh one more question. Do I have to make a Y connector off the CC BEC to power both the RX and my Hitec servo? Maybe this thread is all I need to know? Definitive wiring diagrams for BECs Rx Servos Motors etc. If I set the output of CC BEC to 7.4V and connect it to my RX will the RX now have the correct power for the Hitec servo? Should I just use the CC BEC to power the servo? Hmmm I really am confused. Last edited by ZippoMan; 02-10-2012 at 10:33 AM. |
02-11-2012, 08:16 AM | #383 | |
| Re: Futaba 3PM-MX Crawling Radio - Info and setups Quote:
I would let the ESC BEC power the RX, let the external BEC run the servo. The ESC BEC is FINE for ALL RX's. Some use a special Y connector to connect the servo signal wire (white or yellow) to the RX when running the external BEC direct to the servo. | |
02-11-2012, 08:21 AM | #384 | |
02-11-2012, 10:22 AM | #385 |
Thanks Harley that sounds super easy to me! I love easy ways. I look forward to seeing your diagrams too. My mind is much less confused now. |
02-11-2012, 10:29 AM | #386 |
| Re: Futaba 3PM-MX Crawling Radio - Info and setups |
02-21-2012, 11:51 AM | #387 |
I have another question. Is it normal to have to reverse the throttle channel on the Futaba 3PM-X? I connected all the wires correctly but once I hit the throttle I noticed it was going the wrong way and even the leds on the AE-2 were wrong. I pulled the trigger and the red led lit up and it was going in reverse, i then put the trigger in reverse and the green led lit up!! I figured out how to reverse the channel and it works fine now. I just wonder if I did anything wrong? Hmmmm is it not strange??
02-21-2012, 12:06 PM | #388 |
Yup. Normal. Just depends on what way the ESC has the PWM signal programmed. The reverse has no effect on performance. |
03-18-2013, 11:36 AM | #389 |
Quarry Creeper Join Date: May 2008 Location: Grande Prairie, Alberta, Canada
I hate to revive an old thread but I was wondering if its possible to set this up with dual ESC's in a comp rig?
03-18-2013, 11:38 AM | #390 | |
I would suggest a 4PL. | |
03-18-2013, 12:03 PM | #391 | |
Not quite as good as a radio that supports dual ESC mixing (like a hacked GT3B/GT3C or a Futaba 4PL, etc.) but sorta cheap if you already have a 3PM-x. | |
